Biz Hub 658e
  • antone
    • Oct 2014
    • 344
    [CQ] Biz Hub 658e
    Brand new out the box!All trays paper goes up to fuser and folds up! Checked senors and run motors and they are good ! Any help would B nice!
    Sent from my SM-N950U using Tapatalk
    • 23010
    Re: Biz Hub 658e
    So does it jam? What jam code?
    Does it error out? What error?
    I think we'll need just a little more than that. =^..^=
    • Woxner
      • Jul 2011
      • 853
      Re: Biz Hub 658e
      did you run the fuser drive motor and clutch. bad clutch will do this. had a new c458 do this. also there is a bd just above the mfp on the right called excb that could be bad
      • mo0651
        • 1054
        Re: Biz Hub 658e
        On the door that swings open, there is a push arm that goes thru the frame of copier on rear side just below the fuser. This arm pushes on a spring loaded lever behind frame.
        We have had a couple of machines where that lever was broken and/or popped out of place. causing this issue. Worth a look. It is part of the fuser drive pack.
        • antone
          • Oct 2014
          • 344
          Re: Biz Hub 658e
          Is there a way to see the lever..at all?
          • mo0651
            • 1054
            Re: Biz Hub 658e
            You have to get the door open all the way and look in little square hole. Take a pen and see if that lever inside works. Oh yeah you have to bend down and look in!
            • antone
              • Oct 2014
              • 344
              Re: Biz Hub 658e
              Found it works fine!Any thing else to look for. help!
              • rrrohan
                • Sep 2011
                • 1977
                Re: Biz Hub 658e
                still waiting on jam codes
                • antone
                  • Oct 2014
                  • 344
                  Re: Biz Hub 658e
                  Jam code 3003
                  • rrrohan
                    • Sep 2011
                    • 1977
                    Re: Biz Hub 658e
                    Originally posted by antone
                    Jam code 3003
                      • 23010
                      Re: Biz Hub 658e
                      My vote is for CL8 or PS3. In one case both. =^..^=
                      • allan
                        RTFM!!
                        • 5462
                        Re: Biz Hub 658e
                        Does the sensor flag above the transfer roller pop back freely or plugged in?
                        But i think that would be J2002.
                        Whatever
                        • antone
                          • Oct 2014
                          • 344
                          Re: Biz Hub 658e
                          change the complete fuser drive unit today...no change! help
                          • antone
                            • Oct 2014
                            • 344
                            Re: Biz Hub 658e
                            also complete fuser!!
                            • antone
                              • Oct 2014
                              • 344
                              Re: Biz Hub 658e
                              change that 2
