bizhub c423 1st tray skew
  • gideon
    • 283
    Replace feed rollers - oem. Check tray 1 feed assembly and transport section - looks ok.
    Change registration loop adjustment - no help.
    Tray 2 feed correctly.
    Any suggestion?
    • 14854
    Re: bizhub c423 1st tray skew
    Any suggestion?
    Remove registration assembly. Disassemble, clean and sparingly lube the bushings. Reassemble.
      • 23009
      1) The bizhub 423 has no"C", not color.
      2) Do I really have to ask for a jam code? Come On! Wouldn't it be a great idea to use some of your resources like the jam codes and service manuals? If I showed up to a conversation about jamming without a jam code I'd be laughed out of the room.
      • SmellsHot
        Head Tech
        • 512
        You won't be able to see it without removing, but your bushing is probably wearing on the registration roller....Sometimes you can shine a flashlight at it and see the light through the other side. And it usually only affects tray 1.
        I'd swap out the registration roller shaft and the bushings and you should be good.
        Everyone has the right to be stupid. Some people just abuse this privelage more than others
        • gideon
          • 283
          Thanks for the reply, I'll follow up and I'll post the conclusion.
          My mistake, it is the 423 not c423, the problem is that after posting the title can't be edited.
          (I had another service call on the c451 and I mix the c with the 423).
          • rrrohan
            • Sep 2011
            • 1977
            if your changing the bushings do all 4 not just the 2 on the reg roller
            • allan
              RTFM!!
              • 5462
              Problem is after the first bushing goes the shaft end is chewed up and the bushings don't always last.
              Whatever
              • Downunder
                • Aug 2007
                • 174
                always helpful to include meter count on queries like this -- bushings should be replaced around 700K mark.
                • Ciomu
                  Senior
                  • Aug 2015
                  • 4
                  check paper jam code.
                  this is probably the problem at: CL1 or clutch A02E561100
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4731
                    If you are referring to the older B&W Bizhub 423 and had the registration assembly out make sure the mylar sheet in under the guide when you put it back into machine. If not Tray 1 will jam & skew while tray 2 will work just fine fine.
                    • gideon
                      • 283
                      I replaced the reg. Bushings and clutch and it fix the problem.
                      Thanks to you all.
                      • sogi2011
                        • 3
                        Madness, in a forum where we are here to help each other, what use are these arrogant, useless and rude replies? He never once said it was jamming, he had a skew. Maybe read properly before replying
                        • Synthohol
                          Certified Konica Expert
                          • 5854
                          he posted that almost 4 years ago, why you felt the need to point it out now is just plain bullying.
                          • tsbservice
                            Field tech
                            • 8028
                            Maybe he feels better being RC who knows I will give him a kick start.
                            • copyman
                              Owner / Technician
                              • Sep 2005
                              • 4731
                              Maybe you better read how much help is given on this forum for FREE before posting a negative comment 4 yrs later! If you don't like this forum don't let the door hit you in your ass on the way out!
