Remotely access MFPs over internet
  • CopierNerd
    • Feb 2015
    • 207
    Hi,
    I want to access mfps remotely using internet. Copier is connected with the internet. IP assigned is local but not live IP. how can i access my machine? never tried this before. What are the requirements and configurations to do this.
    Please share your knowledge.
    Re: Remotely access MFPs over internet
    Originally posted by CopierNerd
    Hi,
    ummmmm maybe study the service manual?
    • qbert69
      • Mar 2013
      • 1152
      Hi,
      Are you trying to print to it over the internet or just access the web page of the machine via the internet???[emoji848]
      Sent from my SM-N950U1 using Tapatalk
      REACH FOR THE STARS!!!
      Konica Minolta Planetariums!
      • tsbservice
        Field tech
        • 7981
        If you are more specific about manufacturer it would be easy. In general every brand has its own approach and tools depending on what you need to do. For an example KonMin have Remote panel, CSRC, Vcare etc.
        • Bix
          • Apr 2018
          • 1421
          I saw the WWRSPF. This is a new feature in the CSRC that allows you to access the remote panel immediately, without the user having to press anything.
          • qbert69
            • Mar 2013
            • 1152
            Over LAN or WAN?[emoji848]
              • 22999
              It sounds to me like you're looking for V-Care + Remote Panel. If I understand correctly each registered machine gets billed for. We've attended the webinar. The KM demonstrator tried to present that this as really easy, that the janitor could do it. Our guy that specializes in Toshiba Cloud Connect and Kyocera Fleet Services spent a couple hours and 3 resets to get the first machine connected. I'm skeptical. =^..^=
              • allan
                RTFM!!
                • 5462
                To setup remote panel to work on the local network is easy enough.
                Did it the first time by following the outline in the service manual.
                Used anydesk at the time to get access to a local machine.
                From there you can access service mode, but no one should use the machine and once logged in the customer cant use the machine.
                Sure you can access it remotely with out the help of anydesk or teamviewer if port-forwarding is setup on the router.
                Whatever
                • allan
                  RTFM!!
                  • 5462
                  Any small mistake on the configuration will cause it not to work. Spent countless hours waiting for the service controllers to configure it correctly.
                  Once they got the hang of it it was a simple routine.
                  Many customers had the ports blocked then its a struggle with the IT companies...
                  Preferred the GSM modems over the HTTP setups.
                  Whatever
                  • qbert69
                    • Mar 2013
                    • 1152
                    Easiest way to access admin mode of any machine/mfp is to setup a pc server and install a program such as Teamviewer. That way if you're in a multi brand environment you'll have a unified/ uniform method of accessing web admin of each machine with no pinholing/port forwarding issues. Just my 2 cents worth. [emoji41][emoji1303]
                    • CopierNerd
                      • Feb 2015
                      • 207
                      I do not want to print over the internet using IPP. I just want to access its PSWC using WAN. Machine is already connected with the internet.
                      • tsbservice
                        Field tech
                        • 7981
                        Then that's the setup you may looking for.
                        • allan
                          RTFM!!
                          • 5462
                          You customer must setup port-forwarding on there router.
                          If they don't get a static IP from the provider the WAN IP for the router will change on every restart.
                          DDNS will then need to be used.
                          Why do you need this functionality?
                          Whatever
                          • rrrohan
                            • Sep 2011
                            • 1977
                            install Remote Panel on a server in your office then set them up to connect to it under the client remote panel option on PageScope
                            only downside is you will need them to intiate the connection on the copier for you and provide you the PIN
                            I think only Konica Minolta techs would be able to use remote panel option in CSRC as I have tried it in the past using our own internally hosted Remote Panel server and nothing shows up
                            • Bix
                              • Apr 2018
                              • 1421
                              with WWRSPF you can connect to a customer at 1000km from you, with no problem. You press Remote Panel and the MFP will be available for remote connection. Your client doesn't have to do anything.
