Konica minolta c360i
  • mayorg
    • Feb 2015
    • 53
    [CQ] Konica minolta c360i
    Please can anyone tell me how to enter service mode on konica minolta c360i please
    Sent from my SM-N950U using Tapatalk
  • tsbservice
    Field tech
    • 7987
    Re: Konica minolta c360i
    Use magic button behind the panel. Then same as older models.
    • mayorg
      • Feb 2015
      • 53
      Were is the magic button locate sir
        • 8131
        Pop off a small cover behind the control panel.
        • tsbservice
          Field tech
          • 7987
          Behind the operation panel, remove small cover.
          • Bix
            • Apr 2018
            • 1421
            you can enter without pressing the keys behind.
            Do as always, Counter can be found in Utilities.
            • tech51
              • 846
              • tsbservice
                Field tech
                • 7987
                Now I see what a stupidity I was done... this probably isn't one of my smartest days
                  • 8131
                  KM changed the CE process to stop customers logging in yet immediately after the machine is released its all over the net!
                  • tech51
                    • 846
                    Not changed though has it?
                    Service mode is the same as always and the only reason the buttons are on the back of the panel is to keep the front all smooth and modern looking!
                    • xman
                      • Aug 2010
                      • 48
                      Please help with resetting the service mode code.
                      I have a client with a 360i, previouse service company has changed the code.
                      What is the procedure to reset or change the service mode code please.
