Auto Gradation at CE Mode have no value at "Printer" "FEET"
  • denvertan
    • May 2019
    • 82
    [Misc] Auto Gradation at CE Mode have no value at "Printer" "FEET"
    I am new to this.
    Does the FEET is normal to have no value ?
    I read the service manual it just mentioned to redo the Gradation Reading after restart the machine.
    But after many attempt still value is ZEROS.
  • Leyahné
    • Feb 2016
    • 44
    Re: Auto Gradation at CE Mode have no value at "Printer" "FEET"
    You have to do both
    Sent from my SM-N960F using Tapatalk
    • denvertan
      • May 2019
      • 82
      You have to do both
      Do both ?
      I did both Printer and Copy already.
      Attempted many times but it still no value. A few times I started with Stabilization + Data Initialization. Still the same.
      • qbert69
        • Mar 2013
        • 1152
        Originally posted by denvertan
        Do both ?
        HIT START BUTTON IN THAT MODE!!!...AND DID YA LAY THE PRINTS ON THE PLATEN GLASS TO SCAN & CALIBRATE?! ....It's gotta have that "feedback loop" to ge the numbers to populate!!![emoji848]
        Sent from my SM-N950U1 using Tapatalk
        REACH FOR THE STARS!!!
        Konica Minolta Planetariums!
        • Synthohol
          Certified Konica Expert
          • 5849
          i never see FEET change either, its irrelevant.
          • srvctec
            Former KM Senior Tech
            • Oct 2009
            • 827
            Yep, same here. I just check the bird test page after properly running gradation and if all looks great, then I'm done with the adjustment. I never pay attention to any of those numbers unless there is an image quality problem that can't be resolved by running gradation.
            Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
            • Woxner
              • Jul 2011
              • 851
              you will get 0's after stabilization. you need to get 30 to 60 in colums 2 and 4 in printer and copy area. it can be minus or positive. dont be concerned about feet.
