Bizhub c224e HDD Format Question
  • copier tech
    • 8231
    [Electrical] Bizhub c224e HDD Format Question
  • Albonline
    • Sep 2008
    • 1154
    Re: Bizhub c224e HDD Format Question
    Hi all,
    Today for example I tried a couple of used HDD's in a working C224e but got a C-D011 error.
    i have used 320s and 250s remove all partitions ,install, physical then logical format. works every time. sometimes can get away with just logical. fyi hdds with bh secure will appear as bad drives, in pcs. need physical format in a konica copier. to be usable.
    • tsbservice
      Field tech
      • 8073
      Just follow the manual, there's really no need to preformat HDD, also Emperon controller is Linux system so why Windows partitions?
      • Albonline
        • Sep 2008
        • 1154
        was telling him to format in copier, and how to use a locked drive.
        • tsbservice
          Field tech
          • 8073
          Wasn't aware of your post when typing/sending mine. I see nothing wrong with your advice
          • copier tech
            • 8231
            Thanks for the info.
            So say I took a 320gb drive from a laptop that had Windows XP installed on previously, I would usually plug the drive into a USB caddy to format in Windows.
            Using Win 10 the only options I have is to format as NTFS or exFAT which option should I choose!?
            • Synthohol
              Certified Konica Expert
              • 5910
              you never ever ever format a HDD going into a copier.
              just remove all the partitions in disk management, create a single partition and unplug. do not format.
              install in copier then follow previous advice.
              (albonline) i have used 320s and 250s remove all partitions ,install, physical then logical format. works every time. sometimes can get away with just logical.
