Hello! I bought katun toners after first original toners. I had problem with katun chip. It didn't work and I changed with old original one and black cartridge shows %100 and all other toners shows same ink level, about %60 and no any change after 2.000 print. How can I fix it?
C258 doesn't show ink levels
Re: C258 doesn't show ink levels
Hello! I bought katun toners after first original toners. I had problem with katun chip. It didn't work and I changed with old original one and black cartridge shows %100 and all other toners shows same ink level, about %60 and no any change after 2.000 print. How can I fix it? -
โComment
Buy original toners. Katun are ok if you use on a grocery store or the like.
Sent from my SM-G930V using TapatalkComment
No, not saying by my experience just what I've heard.A tree is known by its fruit, a man by his deeds. A good deed is never lost, he who sows courtesy, reaps friendship, and he who plants kindness gathers love.
Blessed are they who can laugh at themselves, for they shall never cease to be amused.Comment
Toner levels sometimes get high even with original toners. This is because there is no internal sensor that checks the actual amount of toner left.
You will see that the values will settle from the next replacement with original toner.Comment
So to reset the toner count remove the bottle from the machine run it until the machine asks for toner, then fit the used bottle back the counter will reset to full.
โComment
