C258 doesn't show ink levels
  • edi1907
    • Dec 2015
    • 15
    Hello! I bought katun toners after first original toners. I had problem with katun chip. It didn't work and I changed with old original one and black cartridge shows %100 and all other toners shows same ink level, about %60 and no any change after 2.000 print. How can I fix it?
    Re: C258 doesn't show ink levels
    get rid of the shit toners!
    • edi1907
      • Dec 2015
      • 15
      You are so right. I bought 2 sets and when I finish these I will back original toners again.
        • 8128
        He's using 'ink' not toner
        • patrickjlc
          • Feb 2015
          • 217
          Buy original toners. Katun are ok if you use on a grocery store or the like.
          Sent from my SM-G930V using Tapatalk
          • tsbservice
            Field tech
            • 7951
            Toner level shown issue is last one to consider when using aftermarket toners especially on color bizhub.
            No, not saying by my experience just what I've heard.
              sure keep running shit toner and it can mess up the unit even more... Dev units are $$$$ .. but hey do what you want.
              • Bix
                • Apr 2018
                • 1421
                Toner levels sometimes get high even with original toners. This is because there is no internal sensor that checks the actual amount of toner left.
                You will see that the values will settle from the next replacement with original toner.
                  • 8128
                  There is no toner chip on theses bottles genuine or fake.
                  So to reset the toner count remove the bottle from the machine run it until the machine asks for toner, then fit the used bottle back the counter will reset to full.
                  • edi1907
                    • Dec 2015
                    • 15
                    Thank you so much for answers
                    • tsbservice
                      Field tech
                      • 7951
                      From C258 manual.
