Yellow color is not printing Konica Minolta C224e
  • musthafavi
    • Aug 2017
    • 76
    [Misc] Yellow color is not printing Konica Minolta C224e
    I having Konica Minolta C224e MFP, its not printing Yellow color and in color print out not getting good quality
    I have attached here demo page
    After getting this issue, i have been changed Yellow DV unit( DV unit was expired), but still getting the same issue
  • copier tech
    • 8172
    Re: Yellow color is not printing Konica Minolta C224e
    Try swapping the yellow drum with another colour & run the demo page again?
    • tsbservice
      Field tech
      • 8020
      What are other consumables counters. Color developer units are very expensive, did you use new one or second hand?
      Also your color registration is bad, after changing dev unit did you perform Stabilize + Gradation adj?
      • musthafavi
        • Aug 2017
        • 76
        I have been changed Chip and developer powder
        I performed stabilize and Gradation but while performing gradation its not showing gradation values
        • musthafavi
          • Aug 2017
          • 76
          I did , but getting same issue (yellow not getting properly)
          • copier tech
            • 8172
            Here is your issue! fit a genuine Konica Developer UNIT
            • kingarthur
              • 1369
              You've changed "chip and developer powder", you haven't replaced the dev unit then.....
              • musthafavi
                • Aug 2017
                • 76
                Now Yellow DEV unit has been changed with genuine Konica Dev unit, but still having same issue
                • Synthohol
                  Certified Konica Expert
                  • 5847
                  print the yellow gradation pattern, did you clean the laser slit glass with the wand? you didnt mention it.
                  • jwai
                    • May 2018
                    • 509
                    Try the PWB-HV?
                    • Synthohol
                      • 5847
                      The gradient and halftone test patterns in service mode is the best resource to diagnose a CQ issue without removing covers or wasting time and money swapping boards/parts.
                      • tsbservice
                        Field tech
                        • 8020
                        Agree. There's section in every SM regarding 'image quality troubleshooting' in almost all cases running gradations and halftone patterns is part of troubleshooting. They're there for a reason!
                        • copier tech
                          • 8172
                          • hobbele
                            • Nov 2019
                            • 38
                            hey i got the same error...
                            However, it is a C364e. First the power supply was defective.
                            After we exchanged the power supply, it suddenly stopped printing the color yellow.
                            We renewed Dev + Drum Yellow genuine.
                            Then we renewed the HV, then the PWB Assy (FRB)...
                            And now I'm considering replacing the laser/PH.
                            What was the solution here? Did anyone else have the problem?
                            Tobi
                            • Gift
                              • Mar 2011
                              • 2459
                              Tobi
                              Yes - well - kind of - recently with a C3350i that printed full yellow pages sporadically - after replacing the HV there was no yellow at all but funny black dots patterns.
                              Finally we performed a data clear/initialisazion via SP and voila - image was back on track. Do a USB backup first.
