Minolta c284 no update firmware
  • myster
    • Oct 2011
    • 78
    I cannot update the firmware of the machine.
    Does not load the update program by the usb, turning on the machine the panel goes black
    for a while and ends up turning on normally.
    Several pendrives tested and with different firmware versions.
    It may be that the machine is missing the MFP Card Version ??
    I have tried to update from the internet isw, but the mktar_zeus.bat fails,
    I have compressed the folder manually with the command .tar
    the machine downloads the file a161fw.tar from the ftp server but it ends up giving error
    Does anyone know how the update is done correctly?
    thanks
  • Synthohol
    Certified Konica Expert
    • 5463
    Re: Minolta c284 no update firmware
    your method is not even remotely close to the correct firmware installation method.
    read the service manual.
    if you dont have one, become a contributor and ill send it to you.
    • copier tech
      • 7934
      [ATTACH=CONFIG]44715[/ATTACH]
      thanks
      Have a read
      Bizhub 4 Series FW update procedure using USB memory stick V2.pdf
      • Woxner
        • Jul 2011
        • 810
        just take all the files from the folder and put them on the root. nothing else needs to be on the usb
        • myster
          • Oct 2011
          • 78
          Have a read
          [ATTACH]44719[/ATTACH]
          thanks
          Those are the steps that I do exactly, I have already updated several
          bizhub 4 series machines before.
          The problem with this machine is in step 7, the point does not appear in
          the corner, only the panel remains black longer to finish starting normally
          • myster
            • Oct 2011
            • 78
            Thank you
            I know that is what I do, but I can't get the firmware update screen to appear
            • myster
              • Oct 2011
              • 78
              thanks
              Maybe the translation from Spanish to English has not been exact,
              but I don't understand your answer...
              According to the service manual there are only 2 ways to update the firmware of these machines.
              1: as indicated by "the Bizhub 4 Series FW update procedure using USB memory stick V2"
              by Copier Tech.
              2: downloading over a network using the internet ISW, a method that I have not used
              before since it is much more difficult than inserting a flash drive into the service port
              • Synthohol
                • 5463
                I have tried to update from the internet isw, but the mktar_zeus.bat fails, irrelevant
                I have compressed the folder manually with the command .tar WHY????
                the machine downloads the file a161fw.tar from the ftp server but it ends up giving error no tar file needed
                Does anyone know how the update is done correctly? follow copier tech's bulletin
                none of that is right.
                this may be your problem.
                does the root of the drive look like step 5?
                • bushotero
                  • Jan 2020
                  • 2
                  Re: Minolta c364 update firmware
                  Hi,
                  Am looking for the firmware for konica minolta c 364 and i cant find them.Kindly assist
                  rgds
                  GEORGE
                  • copier tech
                    • 7934
                    Originally posted by bushotero
                    Hi,
                    rgds
                    GEORGE
                    Happy to help drop us an email.
                    Firmware Update - Printer & Copier Firmware
