C258 an internal error has occurred
  • edi1907
    • Dec 2015
    • 15
    Hello friends, when I take print or copy it starts work but it gives this error after take 5-6 pages and after it resets job.
    Anybody help me please?
    YouTube
  • patrickjlc
    • Feb 2015
    • 225
    Re: C258 an internal error has occurred
    YouTube
    Does it give you a code for misfeed, jam, etc? Did you try turning it off, unplug the machine, wait 5 minutes, plug it in and turning it back on, to see if it gives any code
    Sent from my SM-G930V using Tapatalk
      • 23010
      If I were to take a WAG I'd say that you probably have developer density issue with one of the colors.
      My suggestion is to go onto service mode and find out what error code is stored. Or hire someone who can. =^..^=
      • edi1907
        • Dec 2015
        • 15
          • 23010
          It doesn't display a code, but a code is stored in service mode. Please look.
          • tsbservice
            Field tech
            • 8064
            Like BC said, it's probably 255x error pending. There are modified bushings.
            Post your machine counter and consumables life.
            • edi1907
              • Dec 2015
              • 15
              • Synthohol
                Certified Konica Expert
                • 5905
                so ya get what ya pay for when using aftermarket supplies.
                sounds about right.
                thats not directed at you yourself, just my feelings on garbage toner..
                see how many halftone test pages you can print so it flushes out the piss toner and replenishes with the good stuff.
                it should stabilize eventually i hope.
                • Bix
                  • Apr 2018
                  • 1421
                  Hi, before replacing anything, I would try to locate the error code.
                  I advise you to contact a local KM technology. In any case, you need to wait about 3 reboots before the C258 will return you an error code. You can also check these errors in the service menu in the Counter list.
                  • copier tech
                    • 8220
                    Non genuine toners cause this exact kind of issue.
                    Even though you have taken out the Katun toner it has now been fed into the hopper & dev unit.
                    As you have been advised multiple times enter CE mode & look what error it has logged.
                    • edi1907
                      • Dec 2015
                      • 15
                      • copier tech
                        • 8220
                        This is frowned upon posting that info on here however a quick Google & you'll find a youtube video of how to enter CE mode.
