Bizhub 368e smearing
  • Gina82
    • Oct 2017
    • 98
    I have a bizhub 368e that creates a smear on the first copy only, after the first copy none of the other images have this issue only the very first copy of each job. If I run a job right after it won't happen, only when I let it sit idle for a few minutes and then try again. I've taken the laser unit out and cleaned it, I've checked the drums for wear on the drum but saw none and I have checked the transfer belt to see if there was any wear but I didn't see anything. Ideas?
    SKMBT_C35320021408540.pdf
  • Bix
    • Apr 2018
    • 1421
    Re: Bizhub 368e smearing
    Hey, it could be simpler than expected (but expensive!). In fact, it is likely that you will have to replace it.
    458e image quality black stripe
    Your stain seems to come from the fuser. This for me is a known problem in the 8e series which, oddly enough, already at just 200-250k starts to have problems with strips coming from the fuser roller.
    If you turn it manually and you look at the surface of the fuser roller, you will notice some signs. If you leave it like this, toner build-up will increase and the streak will soon become more noticeable.
    • Gina82
      • Oct 2017
      • 98
      Any idea why it only does it on the first copy and no other?
      • Bix
        • Apr 2018
        • 1421
        Because it probably cleans itself after a cycle and remains dirty in the end. It may be that by increasing the fuser temperature, this problem disappears. Do you use all OEM?
        • Gina82
          • Oct 2017
          • 98
          Yes, I use all OEM parts and it doesn't look like there are any dents or creases in the fusing unit. In fact, it actually just stopped, I went away for about an hour and gave it time to sit and re tried it and the copies look totally fine. It's driving me crazy, the parts seem fine but I know something is causing it and I don't want it to come back later
          • tsbservice
            Field tech
            • 8020
            Give us total counter and parts life list to start with. Indeed it looks like fuser mark.
              • 23009
              I think it looks like a mustache.
              Take a look at the primary transfer belt. If you get a puncture or wrinkle in the belt it will fill with toner while passing the primary transfer cleaner leaving you a "mustache" that appears approximately once every 4 pages.
              • jwai
                • May 2018
                • 509
                I have similar issue on 368e also.
                It occurred on first print, ONLY on first copy and 1st paper tray, 2nd to 4th trays and bypass OK.
                I got several pages of first copy on 1st tray, and the smear hold on fixed position.
                Checked drum, transfer unit are all good.
                still not fix this case.....
                  • 23009
                  Sample? =^..^=
                  • jwai
                    • May 2018
                    • 509
                    Sample? =^..^=
                    Please check the attached document, thanks
                    • Woxner
                      • Jul 2011
                      • 851
                      There is firmware for this issue. You also have to change a dip switch as well. Problem only happens after it sits.
                      • blazebusiness
                        SanDiegoCopierRepair.com
                        • 1257
                        [ATTACH]44908[/ATTACH]
                        Ditto on the transfer belt unit-----I would check the belt surface for imperfections. Fuser would be my second suspect. Inspect the ITB belt. Then, you could even inspect the ITB cleaner unit and blade.
                        • jwai
                          • May 2018
                          • 509
                          Now the firmware is G00-11
                          Which dipSW need to be changed?
                          • Synthohol
                            Certified Konica Expert
                            • 5849
                            thats the oldest FW out there.
                            X4 is the latest.
                            • Gift
                              • Mar 2011
                              • 2459
                              Can anyone add some feedback about the findings? A tech of mine is currently dealing with exactly the same symptome like the sample in the first post. Guess we should swap the fuser.
