Konica Minolta vs. Toshiba
  • JasonSBE
    • Apr 2014
    • 187
    Any techs that have worked on both lines? The company I work for is considering picking up Toshiba as a second line to offer a lower-cost alternative, as well as get into state sales. How would you compare their image quality, maintenance needs, and ease of repair? Any feedback would be wonderful.
    Re: Konica Minolta vs. Toshiba
    run forest RUN!
    • tsbservice
      Field tech
      • 8056
      Toshiba was my first brand and maybe I learned 90% of my skills from there(hint). But KM are far better in office color machines, also high end machines. You will have rough times if need to switch from KM to Toshiba.
      • JasonSBE
        • Apr 2014
        • 187
        We know that Konica Minolta is the superior product, we aren't looking to replace it. We are looking to add Toshiba as a second brand for state sales(KM does not active bidding for state sales in my state) and a cheaper alternative for customers that don't want to pay the premium. We would probably be doing mostly black and white with Toshiba.
        • tsbservice
          Field tech
          • 8056
          OK, if you didn't get Phil answer let me try again.
            • 23010
            Toshiba color is currently comparable with KM.
            **this is me sitting at the keyboard trying to say something enlightening, but nothing is coming to me**
            Toshiba still rebuilds fuser, drum, and developing units. KM does not.
            I guess I'd have to say that they are different but equal.
            • JasonSBE
              • Apr 2014
              • 187
              I'm not going to go to my boss and tell him that we shouldn't consider a brand because of a movie quote.
              If you worked with Toshiba, how long ago was it? What kind of problems did you find they had? Specifically the black and white lines. Are they user-friendly? Did you ever have to do any network troubleshooting with them? Setting up folder/email scanning?
                • 23010
                On the 4508, 4518 series' the engine is basically solid. The first items to fail before the PM are the upper fuser roller at 100K, the lower drum seal and the charge grid at 150K (then the PM at 210K). If you close the trays hard you'll get a yellow triangle instead of the paper size indication. If you close the trays GENTLE it works fine.
                  ok i guess I should have explained it better.
                  ANY toshiba I have worked on IMHO was a piece of SHIT!
                  PM cycles on the color units were CRAZY! 300-350 for one section 600 for another and 800 for another.
                  most times the 600 group didn't make it to 450pgs. so you do the 330 group.. not the 600pg and then you get another call in no time.
                  We ALWAYS used Tosh parts/kits but the customers were not happy. Some times the corp stock would be on BKO because they were crap.
                  Toshiba .. samsux and some xerox were again IMHO POS's!.
                  you asked for suggestions I gave mine
                  for what it's worth
                  I have worked on most major brands over the 31+ years in industry.
                  and YES as service manager for that company I handled the network end of it .. email..scanning etc
                  from looking at some threads here, they haven't seemed to improved the product much.
                  frankly the A3=A4 xerox (todays lines) seem to have better results as long as the tech is competent.
                  You boss might want to look into wide format or a good label line. Epson Murtec respectively
                  • copiertec
                    • Jan 2016
                    • 2211
                    I second a lot of what most say so far about Toshiba. I have been working on copiers since '94 and worked on Toshiba when they had the Estudio 20 series introduced. That series was not too bad, but it seems Toshiba copiers IMO are not well thought out as far as tech friendliness, most recent Turdshiba boxes I worked on seemed cheaply put together and had strange jam/no jam issues and their HDD's fail often and are way more expensive than any other HDD on the market but could only use their expensive HDD to get them working. I just walked into a real estate office and was told that they are going to be replacing their Konica Minolta with a Toshiba from their other office...little do they know what they are about to do, replace their 284e with a estudio 2550....lmao! Some sales person sure feed them a line of crap!
                    If your boss is going to add these to your line you will see how cheaply made they are, failing HDD's, broken adf handles, and not too tech friendly to replace maintenance items, connectivity, etc., but you get what you pay for. Turdshiba is on top of my list of worst mfp's made along with Xerox, Samsux and Okidata.
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4775
                      Konica Minolta: user friendly, tech friendly, inexpensive to run, and way too many good things to list!
                      Toshiba: Light fuse get away !!!!
                        • 8297
                        I work with several dealers who represent both Konica Minolta and Toshiba product in 2020 across Canada.
                        It is common for Konica Minolta dealers to say they are amazed that when they put out a current model Toshiba they never have to come back for many months.
                        I have many Toshiba's in the field that run extremely well way past their PM cycles making these machines very profitable for dealers.
                        The problem with Konica Minolta is they will promise you the moon but never back up their promises. They are now too big and represent so many product lines that to some extent they seem to have lost their focus. Just review the debates on the Konica Minolta thread about their new iSeries copiers.
                        While Konica Minolta has the lock on Production copiers the Toshiba's are superior to the Konica Minolta's in almost any SMB business situation. KM does have the edge in the rare situation where you need a trifold brochure.
                        All of the blabber about dissing Toshiba earlier in this thread is from technicians who have likely not worked on a Toshiba copier since the eBridge Next line came out in 2016.
                        The Toshiba LCD panel has much superior customization capabilities. Toshiba's app integration with Office 365 is superior to Konica Minolta's.
                        IT Managers comment that they prefer the Toshiba web browser to Konica Minolta's.
                        You will not find a Toshiba dealer who plans to give up the product line for a different copier vendor. If you do, they always comeback in about two years when all of those promises do not come true.
                          • 8297
                          Toshiba colour quality is excellent and equal to any copier vendor in the market. Toshiba no longer offers Fiery as an option as it represents only a small % of potential sales.
                            • 8297
                            Toshiba copiers are easy to repair. The ease of swapping out the paper feed system in the paper drawers is way superior to Konica Minolta.
                              • 8297
                              I often place Toshiba product in places like a pharmacy as print for convenience pay and watch people approach the copier and with no interaction from anyone quickly figure out how to use the copier without assistance.
                              A dirty slit glass or worn out rollers and blades will cause lines on copier just like any other copier brand.
                              I network troubleshoot Toshiba's via TeamViewer and in person almost every day. The most common request is my scan to email is not working. It is not the copiers fault. Something else changed on the customers network.
                              Setting up scan to network folder requires some skill. No more than on a KM.
