Konica Minolta C224e Error Code C-2650
  • mearmi
    • Oct 2010
    • 350
    [Misc] Konica Minolta C224e Error Code C-2650
    Konica Minolta C224e getting Error Code C-2650.
    When we reset/clear error in service mode (Initialization). Machine reboots and working fine.
    And once switch off and on back the same error appears again.
    Please advise.
  • Woxner
    • Jul 2011
    • 849
    • copyman
      Owner / Technician
      • Sep 2005
      • 4712
      Re: Konica Minolta C224e Error Code C-2650
      Remove the SSD and reseat. Push SSD in tight while tightening screw
      • mearmi
        • Oct 2010
        • 350
        I couldn't find the SSD.
        Please find the attached photo.
        • Bix
          • Apr 2018
          • 1421
          • copyman
            Owner / Technician
            • Sep 2005
            • 4712
            SSD is behind the HDD on that model. It would never boot up if missing!
            • allan
              RTFM!!
              • 5462
              Guess they make them different...
              Never seen this layout?
              Whatever
              • tsbservice
                Field tech
                • 8020
                SSDB is behind HDD on non e-series and over the memory sticks on e-series. This machine should be non-e, is my guess.
                @mearmi, if machine is C224 there is FW ver. GA8-K5 that amongst other improvements has this:
                - The troublecode C-2650 may occur after starting the MFP by turning a main power switch off/on or returning from powersave mode.
                • mearmi
                  • Oct 2010
                  • 350
                  It is e version. Returning from power save mode it is working fine.
                  • femaster
                    • May 2011
                    • 1508
                    If you are 100% certain it's an e model, then someone has done something to modify this copier.
                    SSD board location / removal taken from C224e service manual:
                    SSD board location / removal taken from C224 service manual:
                    No matter if you believe this to be a C224e model or not, that board belongs to a C224, there is no way around that. SSD is behind the HDD. Oh, and in your picture, the HDD is disconnected, had you already looked behind it?
