Konica Minolta 300i
  • antone
    • Oct 2014
    • 344
    Konica Minolta 300i
    Some how the bypass won't recognize number 10 envelopes. Comes up with????...I did with size Adj ok..checked all setting! CALLED Koinca....replacement of whole bypass unit ..firmware is ok ect.This is nuts anything someone could add....total 800 copies! help
    Sent from my SM-N950U using Tapatalk
    • 23009
    Re: Konica Minolta 300i
    The way it reads in the operators guide, the bypass tray can recognize as standard sizes: Statement R, Letter, Letter R, Legal, & Ledger. All other paper sizes are set up as Custom. Custom is from 3.5" x 8.5" to 12" x 18", so there is plenty of room for your COM10 envelope at 4.125" x 9.5". There is an Envelope media type, so clearly they do intend envelopes to pass. Amongst the recommended paper types there is a 6 3/4 envelope (3.6" x 6.5" or 95mm x 165mm).
    • antone
      • Oct 2014
      • 344
      box Comm 10...4.8 and 9.5..customer claims envelopes ran before .I bought envelopes to another Konica ( no problem) at all.
      • femaster
        • May 2011
        • 1514
        I don't have a lot of experience with any of the i-series copiers, but if it's like any of the others, you insert the envelope in the bypass and the screen changes on the copier to allow you to select the paper type, and if need be, the paper size.
        I've never had a copier recognize a #10 envelope when set in the Automatic size setting. If it hadn't already been selected previously, you would need to select Standard from the paper size selection, move to the second page in the list of sizes and choose #10 Envelope from the list. From there it will print envelopes all day long, if you desire, though I don't recommend it.
        • Bix
          • Apr 2018
          • 1421
          If before it went and now it doesn't ... maybe a customer driver/software problem? What comes out on the display when you try to launch an envelope print?
          Have you thought about using the first tray? It too was designed for envelopes.
          • antone
            • Oct 2014
            • 344
            crazy problem ..I should B able to put envelopes on bypass choose what type !
              • 23009
              You could consult the operators manual. I found it informative. =^..^=
              • rrrohan
                • Sep 2011
                • 1977
                are you loading it long edge or short edge? i think it has to be long edge
                • antone
                  • Oct 2014
                  • 344
                  short edge..always!
                  • tsbservice
                    Field tech
                    • 8020
                    I'm finding myself reading users manuals very often, especially for newer models. Search is great function.
                    Print
                      • 23009
                      You might be barking up the wrong tree:
                      The main issue I've had with envelopes is not getting the MFP to recognize the paper. The main issue has been the application (either Microsoft Word or Publisher) poorly defining the custom paper size desired.
                      Were it me, I'd create the file in Publisher, Save, then Save As a PDF. In Option > Print Options you can specifically define your image size, orientation, and paper type. Then when you send the print job from the PDF file, the MFP requests loading XX media to the bypass.
                      • Synthohol
                        Certified Konica Expert
                        • 5849
                        in the past i create a printer called envelope, default everything to c10\bypass\envelope media type and save.
                        then on the copier i choose driver priority for bypass tray.
                        then when doing envelopes just choose the new "envelope" queue.
                        good luck
                        • antone
                          • Oct 2014
                          • 344
                          When I use has copier...same problem!
                          • rrrohan
                            • Sep 2011
                            • 1977
                            Does A4 or letter size paper recognise ok?
                            Sent from my Nokia 7 plus using Tapatalk
                            • antone
                              • Oct 2014
                              • 344
                              Yes ...Today went a BH 300i...I selected envelope..paper size..com 10....worked fine!
