SSD storage board
  • jwai
    • May 2018
    • 508
    SSD storage board
    Hi everybody,
    There have expert replace third party M2 size SSD module on i series instead of original Storage Board?
  • Synthohol
    Certified Konica Expert
    • 5814
    Re: SSD storage board
    Sure
    • jwai
      • May 2018
      • 508
      Oh, the specific brands of SSD storage the copier is supported?
      • Synthohol
        • 5814
        to be honest with you, your post was a poor translation to english and my response was apathetic indifference.
        • tsbservice
          Field tech
          • 8002
          It's like that with all his posts, maybe language barrier is too big. I think he asked if new i-series bizhubs storage board(SSD) may be replaced with aftermarket SSD(cheap) than original KM.
          • jotunn
            • 611
            As far as I know, they can't be replaced by any other consumer NVMe disk. There are two kind of NVMe disks mounted in i-Series - PHISON (the bigger) and Toshiba (the smaller one).
            I've tested Toshiba KBG30ZMS256G as the closest to the original (KBG30AMS256G), unfortunately even this was not enough.
            Long story short...
            Disks distributed by KM are most probably whitelisted (by firmware revision number) in the copier firmware - both kind of disks have the same firmware rev. and that's pretty impossible in real world in case of different manufacturers.
            You can't edit firmware revision number, you can't extract firmware from OEM disk controller to upload to another disk, you could probably manually edit revision in firmware controller update image... but it's encrypted.
            • gere1
              • Oct 2018
              • 20
              the question is
              Why do you want a ssd from the i series?
              Are they giving problems?
              has to connect another ssd m2 but I have not seen anything in the manual
              and the microsd thing drives me crazy
              • and
                • Oct 2011
                • 96
                Long story short...
                I found this ssd Apacer AS2280P2 M.2 240GB PCIe Gen3 x2 SSD [AP240GAS2280P2-1] - Uno sguardo da vicino - HW Legend have the same controller PS5008-E8 the same ram Nanya NT5CC128M16JR and the same Nand Flash TA59G55AIV of PHISON (the bigger) If anyone wants to try.
                • copier tech
                  • 8136
                  Originally posted by jwai
                  Hi everybody,
                  On the training course they told us you can remove & format these M2 SSD in using a laptop/caddy.
                  Apparently it is a standard board not unique to KM.
                  • tsbservice
                    Field tech
                    • 8002
                    Or purchase it from KM if you can. It's not expensive.
                    • jotunn
                      • 611
                      First thing - this is not M.2 SSD, it's M.2 NVMe much faster and not compatible with M.2 SSD
                      Second thing - yes, those disks could be read and written with a computer with proper interface, but only from copiers with early versions of firmware, KM in newer firmware has turned on disk locking, so you can't read and write partitions, but you can format whole disk
                      Third thing - you couldn't swap OEM disk with ordinary consumer disks, because they were not recognized as a boot device in a copier
                      Why to swap OEM disk with consumer one? Because earlier disks (Toshiba) were prone to damage, and OEM cost was $300 vs. $25 for consumer one.
                      • EarthKmTech
                        Step aside, noob
                        • May 2009
                        • 2139
                        How rude, lol
                        • Synthohol
                          • 5814
                          at least i was honest
                          "There have expert replace third party M2 size SSD module on i series instead of original Storage Board?"
                          it seemed like a statement and a question all at once. i was lost like a deadhead at a K-pop concert.
