Bizhub c558- error 2156
  • tonerspot
    • Nov 2008
    • 79
    [Error Code] Bizhub c558- error 2156
    One year mashine arround 50k start to pop up code every morning,clear with front door not possible, only when take out belt unit and manual rotating gear can clear code. Cluch on fuser drive is changed, same error. KM told about firmware, but i think for belt assy.I have belt for c258 , can i use it, to ignore belt assy. Tnx
  • GIUBOSS
    • 1431
    Re: Bizhub c558- error 2156
    Compatible models
    Konica Minolta bizhub C224
    Konica Minolta bizhub C224e
    Konica Minolta bizhub C258
    Konica Minolta bizhub C284
    Konica Minolta bizhub C284e
    Konica Minolta bizhub C308
    Konica Minolta bizhub C364
    Konica Minolta bizhub C364e
    Konica Minolta bizhub C368
    Konica Minolta bizhub C454
    Konica Minolta bizhub C454e
    Konica Minolta bizhub C554
    Konica Minolta bizhub C554e
    • tsbservice
      Field tech
      • 8007
      I have one with that error, not intermittent though. Replacing belt fixed it, and I repaired their TBU later with spare parts from another broken TBU.
      As for TBU from C258 I'm not sure it will fit into yours C558, they may be same but are listed as different.
      • ivovb
        • 695
        You need X4 firmware to get rid of the problem.
        BR
        I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
        • tsbservice
          Field tech
          • 8007
          BR
          Now I checked and confirm. Firstly update FW to G00-X4.
          • tonerspot
            • Nov 2008
            • 79
            I was updated today, will see what next.Thanks for all.
            • tsbservice
              Field tech
              • 8007
              Please don't forget to update your post with final resolution.
              Good luck
              • Woxner
                • Jul 2011
                • 848
                here is a bulletin for the belt transfer belt.pdf
                • tonerspot
                  • Nov 2008
                  • 79
                  Same code again, i will order new belt.
