C3350 scan to smbv2 error
  • copiertec
    • Jan 2016
    • 2188
    I have a C3350 and am having issues scanning to folder on Windows 10 Pro. I am wondering if this machine needs a more current firmware in order for it to scan to smbv2? I do have access to this version of firmware A3GN-0Y0-0050-G-002100. I am not too sure about KM firmware so a little help would be greatly appreciated. Is it a firmware issue and would the one I have work? KM-C3350 firmware.pdfKM-C3350 firmware.pdfKM-C3350 firmware.pdf
  • Synthohol
    Certified Konica Expert
    • 5793
    Re: C3350 scan to smbv2 error
    Release Notes: bizhub C3350, C3850, C3850FS Special Controller Firmware Version A3GN30GD883-W51 Support of SMB 2.0 README file
    PM sent
    thanks for being a contributor!!
    • copiertec
      • Jan 2016
      • 2188
      Thank you, Synthohol. I appreciate the help.
      • tsbservice
        Field tech
        • 7963
        If Synthohol wasn't already online I also will be glad to sent you what needed.
        Good luck copiertec
        • himus
          • Sep 2022
          • 1
          Hi everyone,
          I know I am kinda resurrecting this topic but I need the same firmware copiertec shared. Can someone share the firmware?
          • Synthohol
            • 5793
            copiertec has a contributor badge, thats why he/they got it.
            • copier tech
              • 8131
              Originally posted by himus
              Hi everyone,
              Happy to help.
              Printer & Copier Firmware - www.printerfirmware.co.uk
              โ€‹
              • dboxfutzi
                • Mar 2023
                • 5
                Hi Copytechnet Forum,
                I just repaired my broken Konika-Minolta Bizhub C3350.
                It was stuck on "Initialization- Screen".
                After replacing the Mainboard it's working again...
                Downside is the old Firmware of the board:
                ROM-Version Controller A3GN30G0851-W99
                ROM-Version Druckeinheit A3GN0Y00050G002100
                Boot-ROM-Version A3GN99G0100-999
                ROM-Version Panel A3GN02G0152-999
                ROM-Version Scanner A3GN23G0102-999
                Can't scann to NAS folder via SMB anymore because this firmware supports only old unsecure SMBv1 protocol.
                Any chance that somebody can send me the newest firmware?
                Thanx and best regards from Germany
                Dboxfutzi
                • copier tech
                  • 8131
                  Dboxfutzi
                  Yes, happy to help.
                  โ€‹
                  • techsxge
                    • Jan 2022
                    • 660
                    Dboxfutzi
                    contibute a few euros to the forum or buy from copier tech
                    • dboxfutzi
                      • Mar 2023
                      • 5
                      Hi,
                      Can you please PM me a downloadlink for the Firmware.
                      Thank you
                      • techsxge
                        • Jan 2022
                        • 660
                        Hi,
                        Thank you
                        check pm
                        Thanks for contributing to the forum!
                        • dboxfutzi
                          • Mar 2023
                          • 5
                          Thanx @techxge for the firmware file.
                          Sadly I only got the Main- Firmware File "CntUpA3GN30GQ8C3-W51.prn"
                          For the Update there are three files needed.
                          1. Sub Firmware
                          2. Main Firmware
                          3. Engine Firmware
                          Can anyone please provide me with all the necessary files?
                          Cheers
                          dboxfutzi
                          • rrrohan
                            • Sep 2011
                            • 1977
                            if controller FW is older than A3GN30G0206 there is an update you need to do first
                            • dboxfutzi
                              • Mar 2023
                              • 5
                              HI, Controller FW is A3GN30G0851-W99
                              Thanx for the info
                              Still need those firmware files
                              Cheers
