458e Konica
  • hemai2005
    Professional Print
    • 108
    [Error Code] 458e Konica
    Hi guys, dose anyone solve this error before in Konica minolta 458e (C-40A1), its related to (Mechanical controller sub-CPU communication error)
    action taken according to SM (2) Procedures:-1. Turn OFF the main power switch, disconnect and then connect the power cord. Wait for 10 sec. or more after connect the power cord,
    and turn ON the main power switch.
    2. Rewrite the firmware.
    3. machine accepted FW but stopped at 10% at printer/scanner section (NG)
    4. I replaced MFPB but the same issue in the same stage.
    does anyone have idea about that please.
    Thanks.
    sigpic
    Learned a lot will become an expert
  • Albonline
    • Sep 2008
    • 1153
    Re: 458e Konica
    Thanks.
    try the expansion control board pwb-ex
    • hemai2005
      Professional Print
      • 108
      Re: 458e Konica
      what do you mean please ? eMMc ?
      sigpic
      • Albonline
        • Sep 2008
        • 1153
        Re: 458e Konica
        look at wiring diagram its called pwbex , like a printer driver board. loads that the smaller 8 series unit dont have, are fed by it.
        • Guy Milner
          • Nov 2013
          • 61
          Re: 458e Konica
          Have exactly the same on a C368. Replaced MFP PWB - same error. Original MFP PWB put back on with a new emmc PWB - same error? No answers, as yet?
          • tsbservice
            Field tech
            • 8052
            Re: 458e Konica
            I think you meant EXCB.
            • Lone2099
              Re: 458e Konica
              Does anyone know if after the EXCB was changed, the problem was corrected?
              • hemai2005
                Professional Print
                • 108
                Re: 458e Konica
                Sorry, I forget to submit the solution which wasn't related to any boards, we replaced MFPB, we tried and tried and we found in the end something crazy 😄 Just remove the tray 1,2 you'll find the holder with the sensor behind the tray out of the position or broken , corrected by replace it if broken or disconnect it until you replace it.. Thanks.
                sigpic
                • Zoran
                  • 52
                  Re: 458e Konica
                  О n the same series of machine c308 I had an error on MFPB, ICP8E was interrupted.
                  viber_image_2023-06-27_00-08-14-377.jpgviber_image_2023-06-27_00-08-14-656.jpgviber_image_2023-06-27_00-09-54-573.jpg
                  • Ziggy
                    • Feb 2018
                    • 801
                    Re: 458e Konica
                    Thanks.
                    C40A1
                    Known Error
                    Related Products:bizhub C458,bizhub 308e,bizhub 368e,bizhub 458e,bizhub 558e,bizhub 658e,bizhub C258,bizhub C308,bizhub C368,bizhub C558,bizhub C658,MFX-C2590,MFX-C3090,MFX-C3690,MFX-C4590,MFX-C5590
                    Related Options:
                    Error
                    C40A1 at power up Service manual describes it as a Communication Error in the CPU
                    Root Cause
                    Workaround/Fix
                    Check condition and installation of both FDPSB 1 and 2 photointerrupters, holders, and connectors.
                    Replace components as necessary:
                    1. FDPSB/1 or FDPSB/2, p/n A161M50600
                    2. Holder for FDPSB/1 or FDPSB/2, p/n A5C16728000
                    • Catalin
                      • Jun 2018
                      • 1
                      Re: 458e Konica
                      Konica Minolta C258 error C-40A.
                      Hello, I found in tray 2, the sensor was short-circuited, which led to the interruption of the ICP8E resistor. After eliminating the short circuit, I made a bridge in place of the interrupted resistance ICP8E, the result is that now the copier works perfectly. I hope it helps.
                      • tsbservice
                        Field tech
                        • 8052
                        Re: 458e Konica
                        Good job and thank you for sharing
                        • Zesti
                          • Jun 2009
                          • 309
                          Re: 458e Konica
                          This 458e returned to customer after routine customer, at remote location. 40A1 kicked in. checked this thread, asked customer to pull oout both trays, Tray 2 was culprit... Thanks otherwise it was ahell of job as customer site is too far away.
