fiery disconnecting
  • beetle73
    • Dec 2010
    • 44
    fiery disconnecting
    Hi all
    I have a fiery disconnecting itself from the machine around the same time every day.
    Fiery does not crash just disconnects. Turning machine off / on , machine reconnects and all is good
    Happens off the network. Tried a different fiery with same result
    Anyone have any ideas?
  • tsbservice
    Field tech
    • 8053
    Re: fiery disconnecting
    Do you mind to mention machine model and fiery you're working on?
    • beetle73
      • Dec 2010
      • 44
      Km c1060l with Ic415
        sounds to me like he has a timer setting that is going wonkers ... he needs to double check or print out fiery settings and upload.
        maybe CMOS battery in the server is dying?
        • beetle73
          • Dec 2010
          • 44
          Thx for the input
          Tried 2 servers with same result
          Couldn't find any timers that might cause the issue
          • Synthohol
            Certified Konica Expert
            • Mar 2016
            • 5894
            could be auto updating if it happens the same time every day.
            recheck your Fiery configuration.
            • beetle73
              • Dec 2010
              • 44
              Nope
              set to auto update at 3 oclock am
              Neither fiery or machine shut-off
              just loose connection
              • Bix
                • Apr 2018
                • 1421
                Maybe there is some energy saving option
                • mita
                  • Sep 2010
                  • 87
                  Try turning off snmp
                  • beetle73
                    • Dec 2010
                    • 44
                    Thx
                    I will definitely try that
                    • beetle73
                      • Dec 2010
                      • 44
                      Thx for the suggestion
                      This did not work either
                      • Albonline
                        • Sep 2008
                        • 1153
                        get the dsw list from another machine of the same family and compare ,think you may find an undocumented switch has been set.
                        • tsbservice
                          Field tech
                          • 8053
                          Yeah pretty good idea. There's soft switch comparing tool to help with automatic comparison.
                          • Synthohol
                            • Mar 2016
                            • 5894
                            can you ping the copier or open PSWC during its "disconnected" time?
                            i dont remember if the fiery is a passthrough on that model or the copier has its own ethernet connection.
                            can you remote desktop into the fiery and maybe check the system/event logs for clues?
                            maybe a windows service is having an issue or has some scheduled backup or virus scan?
                            backup the fiery settings and run the restore function on the fiery that will clear all settings and be factory fresh.
                            im more interested in if it loses network connectivity or just fiery to copier connectivity through the video cable. could be a wonky VI board but i need more data.
                            • emujo2
                              • Mar 2017
                              • 1579
                              It may have something to do with the marketplace app..We have had more than a few issues with anything that uses the web browser functionality go whacky (tech term) when the app tries to launch itself to check for updates, especially if you can ping the Fiery, the new machines use the Web browser to dispaly on the LCD. E
