total counter changes
  • mike_hartung
    • 39
    [Electrical] total counter changes
    I have had the total counter change on two machines out in the field. One is a bizhub C308. The other is a Bizhub C454e. There was no warning or machine failure. We found out when the customer was called for their monthly meter counts for billing. The counts had changed by hundreds of thousands of copies. What was once a count of over 350,000 changed to just over 62,000. All counters both color, black, and total had changed. These changes have been verified by tech's visiting the customer offices and confirming. Has anybody else had this problem and what causes it and can anything be done about preventing it?
  • tsbservice
    Field tech
    • 7998
    Re: total counter changes
    This is disgusting problem. I have heard that failed battery backup can cause machine to lost some data including counters but on two machines? Are they at same customer?
    • mike_hartung
      • 39
      different customers. One occurred shortly after install. The other customer has had their C454e for over two years now.
      • Bix
        • Apr 2018
        • 1421
        It should go wrong. The data is not kept on a single card and synchronizations are made every hour. If synchronization does not match, the MFP fails.
        Usually when something goes wrong, the change goes from zero pages to millions of pages. Are you sure someone isn't trying to change the counters?
        In the case of the C454e, if I'm not mistaken, it still has the mechanical counter next to the toners.
        • tsbservice
          Field tech
          • 7998
          In case of C308, check in history for error C-D370.
          Counters may be incorrect due to corrupt data in the eMMC board.
          The Workaround would be:
          1. Unset the HDD2.
          Format the eMMC board ( Physical and then logical)
          3. Set the HDD to Installed again
          P.S
          Probably same may happen in C454e if SSD data is corrupt...
          Keep us informed
          • mike_hartung
            • 39
            1. Unset the HDD2.
            P.S
            Keep us informed
            Would this procedure return the meter counts back to what they were before? Or just to prevent a reoccurrence?
            • tsbservice
              Field tech
              • 7998
              Luckily I haven't had to do it yet. I think old counter is lost but to prevent future failures. Did the machines mismatch only total counter, what about parts counts or anything else?
              • mike_hartung
                • 39
                I didn't think about the parts counters. I will have to check on those.
                • Jumping Jack Flash
                  • Jul 2009
                  • 66
                  Mike, this is not a forum where fairy tales are told
                  • femaster
                    • May 2011
                    • 1489
                    That seems a bit harsh for no good reason. Especially from someone who has been a member for nearly 11 years and has accumulated a whole 31 posts, most of which seem to have happened in the last couple days.
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4652
                      Agree this wasn't necessary. Mike asked a good original question. And also man enough to admit he didn't think about checking the parts, etc counters.
