Bizhub C224 waste toner full
  • Bix
    • Apr 2018
    • 1421
    Hi, I met a bizhub C224 today that reported "Waste toner box full".
    I went with a full pan but I found that the customer's pan was already empty. So I think there are problems with the sensor that detects the presence of toner in the transparent measuring cup.
    There isn't even a lot of dirt in that area but even after cleaning, it keeps returning that message.
    Going into the service mod I saw that there are two sensors: the tray presence sensor and the sensor that checks if the tray is full. The former works while the latter works.
    I will replace the FRPB. Do you have any ideas?
  • tsbservice
    Field tech
    • 7992
    Re: Bizhub C224 waste toner full
    If it gives you message "Waste toner full" then it should be Waste toner full sensor (PS101). May be sensor itself contaminated with toner or dust. Blow some canned air into sensor slits.
    It's rather for those sensors die so indeed if anything else is clear you may need new FRB.
    Good luck buddy
    • living
      • Mar 2017
      • 5
      hello
      remove and clean waste tonerWX-103-A4NN-WY3-Conteneur-De-Toner-Usag-pour-Konica-Minolta-bizhub-C224-C258-C284-C308.jpg
      • emujo2
        • Mar 2017
        • 1579
        It sounds lke you are re using the waste boxes.. Have you remove the see through window and cleaned all toner out..your troubleshooting is confusing..you say the tray sensor works and the full sensor works as well. Are you referring to the waste box sensor and do both sensors work?
        "Going into the service mod I saw that there are two sensors: the tray presence sensor and the sensor that checks if the tray is full. The former works while the latter works."
        • Synthohol
          Certified Konica Expert
          • 5808
          IIRC there is a clock disk gear on the lower auger, ive seen them break off and give the same message.
          what if you just install a new WTB? seems to be the best place to start.
          • tsbservice
            Field tech
            • 7992
            Imho my understanding is that ONLY when photocoupler PS101 optical path is blocked after predetermined time machine will give this message. No augers, gears or else related.
            • tsbservice
              Field tech
              • 7992
              Originally posted by emujo2
              It sounds lke you are re using the waste boxes..You have you remove the see through window and clean all toner out..your troubleshooting is confusing..you say the tray sensor works and the full sensor works as well. Are you referring to the waste box sensor and do both sensors work?
              Emujo2, as frequent member here you should already known that Bix is fine and knowledgeable KM tech. And if you weren't such hard hat you eventually may notice that CTN isn't NA region bounded. There is something called language barrier and you know where Berlin is. I'm almost sure that your German spelling may be difficult for Bix to comprehend a word. Most of us other languages speaking techs make great efforts to describe properly our point. Your opinion isn't constructive at all in this case.
              • emujo2
                • Mar 2017
                • 1579
                An opinion would be "I think the problem is ...." I asked for clarification, that's all.
                • Bix
                  • Apr 2018
                  • 1421
                  Sorry for my language, I still have to improve my english. I forgot an essential "not". However, the sensor that detects if the waste toner box is full does not work. The sensor that detects the presence of the waste toner box works.
                  • femaster
                    • May 2011
                    • 1485
                    I think you have found your problem. Like tsbservice said, try blowing out the sensor before you replace it, it only takes a second to clean it, and that second of time could save you some money.
                    • Bix
                      • Apr 2018
                      • 1421
                      Thanks friends, I update you. I cleaned the sensor unsuccessfully, so I proceeded to replace the Front Board. Replacing the Front Board also didn't help. Theoretically I have read that there is a "waste toner near full" sensor and after about 2,000 pages or an image stabilization, the printer returns the waste toner full state.
                        • 23002
                        I just want to clarify that you may be seeing the message "Waste Toner Box Installation Error". It's very common for endusers to need to snap off the flag on the waste bottle, so it is not identified by the machine.
                        I've repaired quite a lot of these flags. At one school the endusers had managed to snap off the flags on the waste bottles in three machines and on two replacement bottles. They were quite efficient ... ly stupid.
                        • tsbservice
                          Field tech
                          • 7992
                          Bix in your initial post by pan and tray did you mean WTB?
                          Also when you test sensors in test mode are they both pass test OK?
                          • Bix
                            • Apr 2018
                            • 1421
                            Hi blackcat4866, thanks for the tip but unfortunately it is not my case. The printer says "Waste toner box full".
                            Hi tsbservice, yes. It is the waste toner box. Only the sensor that detects the presence of the waste toner box works but the one that checks if it is near full does not work.
                            I have replaced the front board but without success.
                            Thanks friends, if anyone has experience on this issue, it is welcome!
                            • tsbservice
                              Field tech
                              • 7992
                              Unfortunately next step left is PRCB or wiring from FRB to PRCB. Before that I will do Clear All Data in case some switch got corrupted value.
