C284e washes out colors
  • mrfuser
    • 1598
    We have a client with a c284e that was losing yellow so we replaced yellow drum and developer and that seemed to work for a while then it came back. We also replaced the itb assembly, cleaned sensors , cleaned sub hopper assembly and it came back fine again and then after a week started losing again. Now it is seeming to wash out all colors and yellow is almost completely gone.
    We watched it adding toner and the levels are about 2% except for yellow at 8%.
    any ideas?
  • mascan42
    • Oct 2008
    • 480
    Re: C284e washes out colors
    Any error codes?
    • Synthohol
      Certified Konica Expert
      • 5735
      is there an abundance of yellow DV in the WTB?
      the white toner bushings leak and send toner into the WTB.
      • mrfuser
        • 1598
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          any ideas?
          Did you use drum kit or new oem drum was it a new dev assy
          Regards Mark
            • 14360
            Have you cleaned the printhead?
            • mrfuser
              • 1598
              Yes oem drum and dv assembly and yes cleaned print head. Get Atc errors for rear sensor and yellow
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                ? Print head
                Regards Mark
                • tsbservice
                  Field tech
                  • 7910
                  Originally posted by mga
                  ? Print head
                  Not PH unit itself I think, just:
                  Troubleshooting
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    Troubleshooting
                    Why do they call it a print head in the user guide it a laser
                    Regards Mark
                    • tsbservice
                      Field tech
                      • 7910
                      True, I also was confused when come to Konicas from Toshiba when they call it LSU - laser scanner unit.
                      Nevertheless it's just laser unit - diode, poly motor and some lenses and mirrors.
                      • copier tech
                        • 8101
                        any ideas?
                        Take out the yellow dev unit, has it lost its developer?
                        If so then most likely you have blocked airflow.
                        Dirt on edge and faded image (blur) caused by developer leakage - Premature Developer Unit Failu.pdf
                        • Walterj
                          KONICA MINOLTA
                          • Jun 2017
                          • 89
                          walvaradocruz@gmail.com
                          Regards.
                          • mrfuser
                            • 1598
                            • Cyclops85
                              • Jun 2020
                              • 14
