C3350 Scan to Email
  • RidleyRumpus
    • Jun 2020
    • 5
    C3350 Scan to Email
    I have just got this unit and am setting it up. Everything else seems to work but I cannot get the Scan to Email to work, when I select it I get "Scan TX Failed"
    (Scan to folder works fine) so I assume that I must have some setting set up incorrectly.
    The manual indicates that I can set up SMTP etc from the touchscreen but the options do not seem to be there, other than enable or disable, I have to go in via the web interface to reach the options. Is this normal?
    Any ideas about what I am doing wrong?
    (Does the C3350 have wireless?)
  • tsbservice
    Field tech
    • 8019
    • Cantechman
      • Nov 2008
      • 228
      Re: C3350 Scan to Email
      did you put the email address in for the device name as well?
      • RidleyRumpus
        • Jun 2020
        • 5
        If you mean the account you are sending too, it is already enabled.
        • wjurls
          • Feb 2017
          • 498
          Use port 587 for gmail. Also as said above, "allow less secure apps" must be set on the gmail account being used. In addition, set the administrator email the same as the authenticating account.
          • RidleyRumpus
            • Jun 2020
            • 5
            I think that that is in the attachment, does that have to be a "real" email address?
            • wjurls
              • Feb 2017
              • 498
              He means the account that is being used to sign in and send from.
              • Synthohol
                Certified Konica Expert
                • Mar 2016
                • 5832
                device email and acct email must match. (yours do not)
                also gmail needs NTLM v2.0 IIRC, pic shows v1 (double check this)
                set 8.8.8.8 for secondary DNS
                let us know
                • RidleyRumpus
                  • Jun 2020
                  • 5
                  let us know
                  Added 8.8.8.8 changed device and act email address not sure what to do re NTLM
                  Still doesnt work.
                  Capture.JPGWish it said more than error in the log :-|
                  • wjurls
                    • Feb 2017
                    • 498
                    Change SMTP port to 587 and select "Start TLS" in the SSL/TLS box. SSL port should then gray out.
                    • wjurls
                      • Feb 2017
                      • 498
                      let us know
                      Even the very latest KM's seem to show that NTLMv1 box. Never seen it be an issue.
                      • RidleyRumpus
                        • Jun 2020
                        • 5
                        Still doesn't work.
                        • wjurls
                          • Feb 2017
                          • 498
                          The 2 circled items must match. Go to the system page and change the administrator email address to the same account name as the smtp account
                            • 30249
                            admin email must be the same as account also turn off pop not needed
                            • Walterj
                              KONICA MINOLTA
                              • Jun 2017
                              • 89
                              Capture2.JPGCapture.JPG[/ QUOTE]
                              Good day:
                              To perform scans via email.
                              Perform a Restore All from Admin Mode> Security> Security Detail> Initialize, and a
                              HDD Format. Make sure the machine has the latest firmware. The latest version of firmware
                              bizhubC3850Series Cont_A3GN30G0851-899
                              bizhubC3850Series Cont_A3GN30G0851-W99
                              Any questions you can write to my email walvaradocruz@gmail.com
                              Regards.
