Konica compatable RFIDeas card readers
  • radd
    • Jun 2020
    • 63
    [Misc] Konica compatable RFIDeas card readers
    Hi,
    Could anyone tell me which RFIDeas card readers are compatable with these:
    C308
    C368
    C754e
    also how i might get the LDD for them.
  • Synthohol
    Certified Konica Expert
    • 5854
    Re: Konica compatable RFIDeas card readers
    Au-205h. R5427000136466
    As far as the drivers, there is a good chance a donation to this site will get you access to such things
    • emujo2
      • Mar 2017
      • 1579
      AK0 and AKU for the 754, AKU only for the C308/C368.
      If it's the AU-205H the 754 has CCID and KBW drivers, the C308/368 were the last models that supported both CCID and KBW
      E
      • karel
        • Mar 2018
        • 44
        Km usb reader ysoft safeq
        • radd
          • Jun 2020
          • 63
          Thanks guys!
          So I should be able to use this on the C308, C368 and C754e
          RDR-80581AKU pcProx Plus Enroll Black USB Virtual COM Reader
          I'm a network guy, my boss has just dropped me in this so not totally sure if that is the best reader for my situation:
          These machines are replacing some Ricoh's. They have existing fobs ( BPT TKX900 impro ) 125khz EM4001 ASK/manchester
          but the card readers left with the Ricoh's.
          I'm trying to avoid replacing a few hundred fobs( if I can )
          Also are the LDD specific to each reader or is there just one for all the RFIDeas models, are they available and are there any other firmware or additional files required?
          any help would be most greatly appreciated!!!
          • emujo2
            • Mar 2017
            • 1579
            Yes, can't help you with the LDDs but...
            You should download the PC prox tool for windows. The AKU has some pretty cool tools including the ability to read up to 4 card types, and to detect and configure the card you want to use. I have no idea what format is being sent to and read by the machine, but the AKU allows for some pretty advanced configuration to make a match. We have been able to use AK0 and AKU models in the same account and they read the card the same (after the configration changes). You just can't mix AU 205H/AK*.. have fun..E
            • radd
              • Jun 2020
              • 63
              Thanks for that, I'll play around with it !!
              • Synthohol
                • 5854
                lemme know if you need the LDDs
                thank you for contributing, its greatly appreciated and others like myself will go out of their way to help.
                • radd
                  • Jun 2020
                  • 63
                  Thanks, that would great if you could
                  • Synthohol
                    • 5854
                    done.
                    • radd
                      • Jun 2020
                      • 63
                      done.
                      Can't thank you enough, respect
                      • radd
                        • Jun 2020
                        • 63
                        E
                        I have the RDR-80581AKU and I have LDDs G26-01 and GW1-01
                        the reader uses keyboard emulation, which LDD is for which, would any one know, or can I try both without bricking it?
                        Also the CCID and KBW drivers are installed or do I need to find them also?
                        Thanks!
                        • Synthohol
                          • 5854
                          the gw1-01 is so you can have a keyboard and the card reader at the same time.
                          also, how did you get a red card? you were respectful and contributed to the site.
                          • radd
                            • Jun 2020
                            • 63
                            Thanks for that!
                            Really Sorry, I bumped an old thread as I thought it was better than creating a new one, wont happen again
                            • Synthohol
                              • 5854
                              well i gave you a positive rep point.
                              dunno if it will reverse your red one but i had to try.
