Konica compatable RFIDeas card readers
  • Synthohol
    Certified Konica Expert
    • 5841
    #31
    Re: Konica compatable RFIDeas card readers
    glad to see your red card has been reversed
    • radd
      • Jun 2020
      • 63
      #32
      Me too! Thanks for that
      Quick question, could my problem be that this particular model
      RFIDeas RDR-80581AKU
      is just not compatible with Konica,
      I have read mixed reviews, because as you said earlier there doesn't seem to be communication between it and the C368.
      • Synthohol
        • 5841
        #33
        are you able to backup the address book to USB and reset the machine? (initialization, system data clear)
        reinstall the movie data and the drivers, reenable the HDD as the reset uninstalls it.
        then see if you can try again.
        • radd
          • Jun 2020
          • 63
          #34
          Tomorrow afternoon
          Should be able to, this machine is in the office, so address book is empty ( do I still need to back it up )
          which drivers?
          do you have the service manual for it, that would be a great help.
          Still early days for me with these machines, but you're warp speeding my learning curve
          Edit: I also upgraded it to the -X4 firmware earlier but no help ( did manage to get a C155 error, happens I guess if you connect the wrong finisher to it
          • emujo2
            • Mar 2017
            • 1579
            #35
            The AKU for the c368 (no models after the C368 family are supported for both) has both CCID and KBW drivers. If you are using the CCID LDD you will also need to program the Product and Vendor IDs once user authentication has been enabled. If you are using the latest KBW driver your MFP must be at function version 4, and you need to build the KBW driver using the LDD tool. By default the LDD has the AU205H Vendor and Product IDs installed, these must be changed to the AKU. If you are getting C-C*** errors you are using a LDD that is not supported by firmware or the incorrect model. If you are getting communication errors (Can't connect) then you probably do not have the Vendor and Product IDs programmed correctly. These values can be found when you plug in the reader to the PC prox tool. E
            • radd
              • Jun 2020
              • 63
              #36
              Great info
              PcProx is really good, ( thanks! ) I was able to match my Card ID and config the reader to get the correct output for Papercut!
              A few questions:
              I have 2 LDDs: G26-01, GW1-01
              Are they specific for RFIDeas readers?
              The LDD tool is that Konica, where would I find it?
              Do I just need to put the device id's into and build ( like I used to do with the Nvidia drivers to support older cards )
              MFP at function level 4
              Is this at Stop / 9 Management function ( my currently says Version 2 )
              Where do I change the default Vendor and product ID from AU205H to AKU?
              Yes I get C-C180 error ( how do I know if it's model or FW related )
              Thanks for any help you give
              • Synthohol
                • 5841
                #37
                Soft switch 25 change it to B0 for latest function level.
                Also the ldd drivers are for the au-205h which is the only model for the 8 series listed by KM.
                • tsbservice
                  Field tech
                  • 8019
                  #38
                  C-C180 Device Driver is missing or the incorrect driver is installed.
                  • tsbservice
                    Field tech
                    • 8019
                    #39
                    Originally posted by karel
                    Km usb reader ysoft safeq
                    For Ysoft card reader you will need this loadable driver:
                    A7AH0Y0-A521-G00-01_Y-Soft
                    • radd
                      • Jun 2020
                      • 63
                      #40
                      Thanks!
                      That's why I keep getting the C-C180 when I try to use them with the RFIDeas reader then?
                      • radd
                        • Jun 2020
                        • 63
                        #41
                        Thanks!
                        Yes I see, because the LDD isn't correct for my RFIDeas reader correct?
                        • radd
                          • Jun 2020
                          • 63
                          #42
                          Unfortunately I don't have a Y-Soft reader, am I waisting time trying to get the RFIDeas reader working with the 8 series?
                          • radd
                            • Jun 2020
                            • 63
                            #43
                            @tsbservice
                            Thank you Sir
                            you PM quota is over the limit
                            • emujo2
                              • Mar 2017
                              • 1579
                              #44
                              A7AH0Y0A831G0000 would be the correct driver to use with a C368 at function version 4.2 and the AKU is in CCID mode, Vendor and Product IDs need to be configured after Authentication is enabled.
                              C258_C308_C368 _G00-F4.2_AKU.Zip would be the correct driver to use for a C368 at function version 42, and the AKU is to be in KBW mode. LDD would still need to be modified with the LDD Tool to create a LDD with the AKU product and Vendor IDs
                              With paper cut you probably want the KBW driver. Sorry that I cannot just give you the files and/or the config tool. All this stuff is the property of KMBS. If you are a dealer or direct, PM me with your KM email address and I'll reach out to you..The tool and the drivers are all available on the private KMBS site. E
                              • radd
                                • Jun 2020
                                • 63
                                #45
                                Thank you, that clarifies a lot.
                                I completely understand.
                                Unfortunately we are justing getting started as a reseller and are still working towards KM status.
