Konica compatable RFIDeas card readers
  • radd
    • Jun 2020
    • 63
    #16
    Re: Konica compatable RFIDeas card readers
    Originally posted by Synthohol
    well i gave you a positive rep point.
    dunno if it will reverse your red one but i had to try.
    Much appreciated
    I also deleted my post in that thread, not sure that helps either.
    I always like to learn things the hard way
    • Synthohol
      Certified Konica Expert
      • 5840
      #17
      but learning the hard way sticks with you better IMO.
      • radd
        • Jun 2020
        • 63
        #18
        Originally posted by emujo2
        Yes, can't help you with the LDDs but...
        You should download the PC prox tool for windows. The AKU has some pretty cool tools including the ability to read up to 4 card types, and to detect and configure the card you want to use. I have no idea what format is being sent to and read by the machine, but the AKU allows for some pretty advanced configuration to make a match. We have been able to use AK0 and AKU models in the same account and they read the card the same (after the configration changes). You just can't mix AU 205H/AK*.. have fun..E
        I can see why you said have fun now
        Currently I have loaded Ldd G26-01 using Service mode / System2 / Driver install
        Then restart
        Service mode / Stop > 9 / authDevice2 / card / end
        turn off
        connect usb reader: RDR-80581-AKU (RFIDeas)
        restart
        Then I get: 2 errors
        Turn on the authentication device
        Please Load Ldd
        I'm trying it on a C368 with firmware:
        ManVersion - 12
        A7PU0Y0-3000-G00-W1
        Not sure exactly where my issue lies
        • Synthohol
          • 5840
          #19
          the LDD you installed is if you need both a keyboard AND the card reader.
          is this the case?
          if not use the other one i gave you.
          btw, G00-X4 is the correct latest base FW, i suggest you try it as well.
          there is no W1 FW.
          • radd
            • Jun 2020
            • 63
            #20
            Yes, sorry G00 - W4
            I have tried both just in case, but the results are the same.
            I will try the upgrade to G00-X4 as I understand that is better for Papercut?
            Thanks again for all your help
            • Synthohol
              • 5840
              #21
              just to ask, where are you plugging in the card reader? which USB port?
              • radd
                • Jun 2020
                • 63
                #22
                I have tried with each one including the front by the touch panel!
                • tsbservice
                  Field tech
                  • 8019
                  #23
                  You need to connect card reader FIRST(use the rightmost usb port just to be sure) then LDD then stop 9 and under Management Function Choice - Authentication Device 2 - Card.
                  • radd
                    • Jun 2020
                    • 63
                    #24
                    Thanks, tried that still getting the same thing.
                    • Synthohol
                      • 5840
                      #25
                      do you know for a fact the reader works?
                      if its used was it on another MFG? maybe try pcprox and see if it even shows up in the window.
                      • tsbservice
                        Field tech
                        • 8019
                        #26
                        Radd, can you post screenshots?
                        • radd
                          • Jun 2020
                          • 63
                          #27
                          Brand new reader, works fine in pcprox and reads my tags no problem.
                          • radd
                            • Jun 2020
                            • 63
                            #28
                            Can't at the moment, just left the office, have customer install tomorrow morning, but I'll try later in the day
                            Thank you and Synthohol for all your help
                            • tsbservice
                              Field tech
                              • 8019
                              #29
                              Yeah, just Synth is the man. Always be and always will.
                              • radd
                                • Jun 2020
                                • 63
                                #30
                                Well, your both top of my list
