C250i Self Diagnostic on start up
  • byronf
    Senior Member
    • Sep 2017
    • 109
    [Misc] C250i Self Diagnostic on start up
    Hi Guys,
    I have a C250i that boots up straight into service mode self diagnostics. There are no errors all check results "OK". I have updated fw to G00-79 with no luck and I have redone the entire set up again, the machine is functional however the client is not happy to keep exiting the service mode screen whenever yhe machine is powered up.
  • tsbservice
    Field tech
    • 7910
    Re: C250i Self Diagnostic on start up
    Do G00-7B FW.
    • Synthohol
      Certified Konica Expert
      • 5735
      Unless the button is stuck in behind the panel?
      Don't forget to change sw switch 25 to the newest function level.
      I forget the hex, maybe someone can fill in that blank faster than me.
      • tsbservice
        Field tech
        • 7910
        Hex 10.
        • Bix
          • Apr 2018
          • 1421
          Do G00-7B FW.
          I didn't like this firmware, it did strange things for me. Now I prefer to experiment with GC1-7B
            • 22929
            If the hex switch isn't changed, this is exactly what you'll get. It drove our in shop techs crazy for a few days.
            • ivovb
              • 695
              Starting machine with Power key pressed will cause Self diagnostic. So check if Power key is somehow constantly blocked.
              BR
              I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
              • tsbservice
                Field tech
                • 7910
                No stuck buttons involved just do FW and correct function version.
                • byronf
                  Senior Member
                  • Sep 2017
                  • 109
                  Hi All,
                  Updated GC1-7B and correct the version and all is working normal.
                  Thank you all for your assistance.
                  • Synthohol
                    • 5735
                    and thank you for the update
                    • b.amur360
                      • Jan 2016
                      • 6
                      You can stop the MFP to automaticly perform self diagnostics by adjusting dip sw 163 to hex 00
                      the default is to run auto diagnostics when it thinks it has a problem, but this can confuse customers who see the self diagnostics screen!
                      I prefer to turn this off.
                      BR
                      • Albonline
                        • Sep 2008
                        • 1131
                        im running gc1-7b seems to be as stable as 45 but without the issues. just remember to disable marketplace before flashing.
                        • Bix
                          • Apr 2018
                          • 1421
                          Hi, I'm only reading now.
                          What will happen if this is not done?
                          • Albonline
                            • Sep 2008
                            • 1131
                            The flash has sometimes been corrupted.
