Re: Bizhub C353 "Install the imaging unit and close all doors" error
It sounds like you don't have a new enough firmware installed. It's been a long time since I've had to set this model, but I believe the Long Life functionality you are looking for came in one of the later firmware versions. Most likely the version on your machine is prior to those switch settings being implemented. That and I don't think it would have helped out your situation anyway, as it sounds like it thinks the units aren't even installed, so long life settings wouldn't do you any good in that case anyway.
