C454e air print function
  • ck1
    • 485
    May i know how to enable air print function , i upgrade firmware to A5C10Y0-F000-G20-M1 still can't found ( missing ) to on it .
  • copyman
    Owner / Technician
    • Sep 2005
    • 4700
    Re: C454e air print function
    These older models were not the best for mobile printing. See attached. Hopefully there is something in there that may help you.
    • ck1
      • 485
      thanks for sharing . But my issue is no button to on this function at adminstrator- network setting - air print
      • copier tech
        • 8144
        After you have updated the firmware you need to enable function version 7.
        In CE mode System 2 > Software Switch Setting>Switch 25 set to HEX 60.
        Reboot then you will have the AirPrint option in admin mode. (its off by default)
        SW 25 to HEX 60.pdf
        • ck1
          • 485
          [ATTACH]46029[/ATTACH]
          yes i follow the step ,but still no air print function at page two . now i blur.....
          • copier tech
            • 8144
            There are two other SW that may need to be changed.
            I would also update to the latest firmware version GDN-M1
            Bizhub 4e Series - AirPrint Additional Information.pdf
            • ck1
              • 485
              [ATTACH]46039[/ATTACH]
              thanks for sharing , i will try and update soon ...
              • ck1
                • 485
                Yes is work .Thanks so much
                • copier tech
                  • 8144
                  Great! thanks for the feedback!
