C552ds hangig for logo konica and not download fimware scanner
  • saeidss
    • Jul 2015
    • 30
    [Dead] C552ds hangig for logo konica and not download fimware scanner
    Update frimware c552ds erore scanner dowliad n.g
  • copier tech
    • 8176
    Re: C552ds hangig for logo konica and not download fimware scanner
    Try another USB stick & a fresh copy of the firmware. A stick no larger than 2GB
    If not try the NVRam firmware.
    • saeidss
      • Jul 2015
      • 30
      Tested not solve problam
      • saeidss
        • Jul 2015
        • 30
        Imgur: The magic of the Internet
          there is an error in the files.... did you follow copier techs recommendation as to get a fresh copy of the firmware?
          what version are you trying to use?
          • saeidss
            • Jul 2015
            • 30
            A1DM0Y0-F000-G00-D1
            A1DM0Y0-F000-G00-D1.zip
            A0P00Y0-F000-GQ7-D1(00)_2ineo plus 452 552 652(DS.exe
              A1DM0Y0-F000-G00-D1
              Are you unzipping to the thumb drive?
              2gb FAT32 should be clean before moving files to it
              • copier tech
                • 8176
                So you tried the NVRAm firmware, how far did it get etc?
                • saeidss
                  • Jul 2015
                  • 30
                  The firmware gives a scanner error. I called 4 firmware with several different usb Again, it's freezing, and the device's scanner doesn't move at all, and the device hangs on the Konica logo What is the scan board? It does not download the frinware, but the firmware downloads adf.
                  • tsbservice
                    Field tech
                    • 8020
                    Delete any other files ending in the ".tar" extension. Only one firmware file can be in the root of the USB thumb drive when flashing the machine.
                      i wonder on his procedure,,,, he is rather vague in his explanation of it.
                      • tsbservice
                        Field tech
                        • 8020
                        We still don't know what is the main cause machine to stuck at boot up. Maybe another problem is present and FW failed to update is consequence.
                        • saeidss
                          • Jul 2015
                          • 30
                          The mfp problem was fixed by replacing this part
                          But it was very strange why the scanner firmware downloaded n .g
                          • Woxner
                            • Jul 2011
                            • 851
                            the mfp may have fixed it but were you using the c552ds firmware or the c552 they are different
