bizub c258 Image Quality Yellow
  • Ruumduuly
    • Jul 2020
    • 5
    [Dead] bizub c258 Image Quality Yellow
    Hello Users!
    I got Problems on my C258, full dot patern Yellow, changed dev, PCU, ITB, nothing changed.
    Anyone can help ?
    BR
  • Bix
    • Apr 2018
    • 1421
    Re: bizub c258 Image Quality Yellow
    Hi, are you using original toner? How many pages has it done?
    If it only does this with yellow, the glass of the PH Unit may be very dirty. Take the wand and clean the window of the PH Unit.
    Obviously you have to do it in the yellow section.
    • Ruumduuly
      • Jul 2020
      • 5
      Hello again
      Allready cleaned complete Laser Unit. Problems only with yellow , using Original Toner; the machine is quite "new" 80k B/W and 2,5k Color sites
      Thx 4 quick answer, any other ideas ?
      BR
      • copier tech
        • 8200
        Originally posted by Ruumduuly
        Hello Users!
        Anyone can help ?
        BR
        Stop the machine mid run & remove the transfer unit what does the yellow image look like on the belt?
        Looks like the y transfer roller bushing is broken in the transfer unit.
        • Ruumduuly
          • Jul 2020
          • 5
          Allready changed Transfer Unit, 1 new One, 1 "old-used" from a perfectly working machine, still Yellow troubles
          Image on the transfer Unit looks like the printed one (.pdf from 1st post) = Image bad on transferUnit
          • tsbservice
            Field tech
            • 8053
            Very strange. By changing developer you mean whole developer unit or just powder? Yelow magnetic brush nice and even? New OEM yellow drum unit, not some modified one?
            • Synthohol
              Certified Konica Expert
              • 5892
              what does the brush on the DV unit look like?
              • copier tech
                • 8200
                He replaced the dev unit so unlikely a new one has the same fault.
                • Ruumduuly
                  • Jul 2020
                  • 5
                  Summary of Day 4 - repairing my C258
                  new Dev Unit Y
                  new PCU Y
                  new Transfer Image Belt
                  used Laser Unit from another working machine
                  connectors off/on High voltage Board & FrontBoard behind waste toner box (where DEV units and registration ...are connected on)
                  thx@all now time for weekend & BBQ
                  BR
                  • tsbservice
                    Field tech
                    • 8053
                    Any error codes present or in history? Almost looks like distance between developer and drum is too wide in areas where image is missing. Are we sure sample is LEF?
                    • fatduke
                      • Jun 2020
                      • 75
                      Hi man,
                      first use original toners, then check consumable status: drum, developer, transfer belt, transfer roller.
                      Then if the problem will be again empty yellow parts on printed paper, evaluate to change or refurbishind yellow developer.
                      Cheers
                      • copier tech
                        • 8200
                        Originally posted by fatduke
                        Hi man,
                        Cheers
                        Read the previous comments before you post!
                        • tsbservice
                          Field tech
                          • 8053
                          Exactly! Should be even in Forum rules.
                          • Ruumduuly
                            • Jul 2020
                            • 5
                            No Error Codes. Sample is SEF. Now getting back to office trying to check - "modify" distance between drum and dev Unit.
                            • Toxic
                              • 698
                              Try same test print on A3 paper and post again.
                              Did somebody before "modify" DR/DV distance?
