C224 2nd Paper Cassette won't work
  • fatduke
    • Jun 2020
    • 75
    Hi everyone
    I got a very frustrating and big problem on a C224.
    2nd cassette won't work. I changed bushes, rollers, clutches, clean all the part with isoprop,
    put grease on gears, but no luck.
    Machine show me the paper block on grid 2-9 (on machine guide image on display)
    Anyone had this problem?
    Attached pic
    TY
  • Synthohol
    Certified Konica Expert
    • 5854
    Re: C224 2nd Paper Cassette won't work
    have you removed tray 1 and watched tray 2 try to feed paper?
    see if the rollers turn or the shaft or the tray lifting high enough etc..
    please report visual clues.
    • Max
      • Oct 2011
      • 561
      Sponge pad on the picture is coming off. Edges appear to be blocking the exit. Try removing it and don't forget the sticky backing too.
      • allan
        RTFM!!
        • 5462
        Make sure the right spring is installed on the separation roller.
        There i a spare spring to enable thin paper to feed clipped somewhere on the unit.
        Whatever
        • fatduke
          • Jun 2020
          • 75
          UPDATE
          I FOUND THE PROBLEM BUT NOT YET THE FIX
          Hi everyone,
          I made it (half way), so...
          I found like I said before the problem... gears slides too much but if i pressure the gears and turn the paper pickup section, the mechanism works perfectly...
          So, how I can fix this? Why gears only with pression works...??
          I also checked single gears but I saw no damage or broken teeth..
          TY
          • copyman
            Owner / Technician
            • Sep 2005
            • 4732
            Originally posted by fatduke
            UPDATE
            Hi everyone,
            TY
            Is the "bottom" plastic piece that the door hook latches onto broken? Move with hand because it can look good but can still be broken. When it is broke the bottom part of door isn't held closed enough and only tray 2 will jam.
            • zoool
              • Nov 2016
              • 52
              try stretch the spring in doors. under white plastic rollers between 1st and 2nd tray
              • femaster
                • May 2011
                • 1514
                UPDATE
                Hi everyone,
                TY
                Is that clutch in your pictures mounted properly? The white tab that sticks out (on the left side in your pictures) is severely bent. That should be sticking straight out from the body of the clutch, but for some reason yours it bent towards the drive gear side. This is leading me to believe that maybe that tab it not properly positioned to be held in place by the framework of the feed unit.
                • fatduke
                  • Jun 2020
                  • 75
                  The bottom piece is bend for the try. If i pull out, gears work.
                  • femaster
                    • May 2011
                    • 1514
                    Do you have another unit you can compare it to? Perhaps you are missing an E-clip somewhere and that is why it's so sloppy?
                    • fatduke
                      • Jun 2020
                      • 75
                      Hi,
                      I will compare with another soon as I can but, every time I change something on paper cassette, I make a pic in order to avoid mistakes :-)
                      But it seems all ok as I remember.
                      Right now I can't see the trouble cause is not in my laboratory.
                      Will check it.
                      TY
                      • blazebusiness
                        SanDiegoCopierRepair.com
                        • 1257
                        I think femaster is really on to something with the possibility of a missing clip causing all the play. I've certainly seen stuff like that before. Focus on that for starters.
