C364 error code e3-01
  • wpcadet
    • Jun 2011
    • 22
    so... Sharp Dealer with an account with 63 units...one being a C364 KM. We were asked to take it under service 5 years ago. Well, we are near else end and of course this happens now. Any ideas ? HDD Firmware update ? Would need firmware procedure or HDD reformat info if one of these is the issue. One of those stressful times we all endure ..gotta love it !
  • Synthohol
    Certified Konica Expert
    • 5846
    Re: C364 error code e3-01
    3.17.5 CE301,CE302,CE303,CE304,CE305
    (1) Contents
    Trouble type Referring incorrect memory
    Incorrect command
    Finished due to error inside Qt library
    Finished due to error outside Qt library
    Program forced to stop
    Trouble code CE301
    CE302
    CE303
    CE304
    CE305
    Rank C
    Detection timing Error occurred with the process inside the MFP controller
    Trouble isolation -
    Relevant electrical parts MFP board (MFPB)
    (2) Procedure
    Step Action Control signal Location of electrical components
    1 Check the connectors on MFPB for proper connection
    and correct as necessary.
    2 Replace MFPB
    re-seat everything, ram, ssd, all connectors if still no joy MFPB
    not worth it, the board cost more than a newer used e series off lease!
    • copyman
      Owner / Technician
      • Sep 2005
      • 4718
      Did you try a trouble reset? If not may have to format the hdd. Not a big deal. Go into service mode. You will need to load animation f/w. Also should load latest reg f/w.
      It's all in service manual. I know some here are saying they will send manuals & f/w to contributers of this site. Make a small donations and someone will send you what you need. I stopped promoting donations to this site since it doesn't offer any moderation.
      • femaster
        • May 2011
        • 1512
        It could certainly be a firmware update. The CE301 is a fairly generic error code. It can be caused by all sorts of things, but the first step in the list of corrections is to update the firmware. The earlier firmware for both the the straight (C364) and the e-models (C364e) had issues with the E301 error which were corrected. What is the firmware version at currently?
        Model:
        bizhub C364
        Code: CE301
        Install the following special firmware firmware.
        • bizhub C224/C284/C364 - special firmware version A1610Y0-F000-GCH-72
        • tsbservice
          Field tech
          • 8020
          Like femaster said. The first thing I would do with this code is to update FW. They(Konica) claim in almost every new firmware made some kind of instance of C-E301 fixed.
          • rrrohan
            • Sep 2011
            • 1977
            the amount of solutions ive heard over the years for this, its like KM dont even know the fix. I was told, disable CSRC and MarketPlace/Web browser, to update firmware, to replace MFP Board
