konica 224e making alot of noise when starting and when printing colors
    • 8184
    Re: konica 224e making alot of noise when starting and when printing colors
    Originally posted by Mitch Barron
    Hello guys How you all doing today?
    Today I am seeking for your support and expetise because my head is spinning now, I have this konica 224e, it is making alot of noise same noise when you have clog on the transfer belt, I thought it was that so I did the usual clean the cleaning blade and the restoner canal, put it back and the noise continue the funny is when you make black and white copies it make no noise but when you make colors the noise comes back or when stabilizing. I had change the transfer belt motor, toner motor, drums motor so I am giving up so need your help guys any tips.
    thanks
    You say 224e but mention colour so this model is a C224e?
    • mga
      Copier Technician
      • Dec 2010
      • 1393
      Originally posted by Synthohol
      we still dont know if the copier is color or not based on the title.
      Well spotted we take things for granted but I think he said it only happens on colours prints
      Regards Mark
      • femaster
        • May 2011
        • 1514
        I recently installed WTB for color bizhub C654e into mono bizhub 654e...does it make my machine color
        Only if it was partially filled and you didn't empty it first...
        • Synaux
          • Mar 2012
          • 1224
          #19
          Well turned into a fun read ... I assume this doesn't have a color transfer belt installed and no color IUs
          +1 to CMY test prints in SM and the only thing I can think to add is to utilize Load Check instead throwing parts at it
          • Mitch Barron
            • Mar 2013
            • 180
            #20
            Synthohol, sorry for the late reply but if I am talking about color printing I guess that machine is a color one, just to clarify that to you.
            • Mitch Barron
              • Mar 2013
              • 180
              #21
              +1
              Just confirming ... is this a C224e. You cannot do color on a 224e. =^..^=
              just to confirm, yes is a 224e, Here in europe is a develop 224e, and yes you can print color it was printing fine till my boss when to replace TB unit and then the noise appear.
                • 8184
                #22
                So it must be a C224e ?
                • Mitch Barron
                  • Mar 2013
                  • 180
                  #23
                  [QUOTE=copier tech;1534690]So it must be a C224e ?[/QUOTE
                  yes it is a C224e.
                  And as I said before it make the same noise as when the cleaing blade for the transfer is clog, but I had clean it and also the pipe that goes to the rest toner, but nothing the nosie keeps happening when the machine start or when it stabilizing, and when I make color printings, when I make color printing the noise come back.
                  I have today changed the developer units but same noise.
                  • Blizzoo
                    • Aug 2013
                    • 609
                    #24
                    Hmm, I would check every colour drum units for any blocked waste/damaged gears on toner waste discharge area. I had a broken waste auger on Magenta cleaning unit on a different brand of copier clicking only in colour printing/copying.
                    • Mitch Barron
                      • Mar 2013
                      • 180
                      #25
                      thanks Bliz, I had done all that nothing found, I just finished swapping the printing board but same thing. guess I have to break the whole machine down to see what is going on, since I had tried every advice from you guys here.
                      • tsbservice
                        Field tech
                        • 8028
                        #26
                        I don't remember but did you tried another TBU?
                        • Synaux
                          • Mar 2012
                          • 1224
                          #27
                          oh... ok...
                          And...
                          A clue.
                          • Synthohol
                            Certified Konica Expert
                            • Mar 2016
                            • 5853
                            #28
                            Does it print all 4 colors correctly?
                            Maybe theere is still packing material you missed on the new belt?
                              Maybe there is still packing material you missed on the new belt?
                              I NEVER let my boss " fix shit " WHY you ask? because he is a TOTAL flaming idiot... he didn't even ' manage ' the employees.
                              he thought MICRO MANAGING was the 'wave' of the future ... that's fine at McD's but every employee was above the age of 35.... most in the 40-50yr range.. myself I was the oldest... yes EVEN older than he was .. I was in the industry for 10+ years more than him.
                              • mga
                                Copier Technician
                                • Dec 2010
                                • 1393
                                #30
                                Europe Develop it would be +224e or a +224 for colour not 224e
                                Regards Mark
