konica minolta c454 copying problem
  • romario
    • Jun 2020
    • 185
    [Error Code] konica minolta c454 copying problem
    [ATTACH] 46347 [/ ATTACH]
    [ATTACH] 46347 [/ ATTACH] [ATTACH] 46347 [/ ATTACH ]
    thanks
  • femaster
    • May 2011
    • 1458
    Re: konica minolta c454 copying problem
    You need to go through the "setup procedure" on the copier to eliminate the colored lines. It needs to be done exactly listed in the manual, or it will not work.
    You should be able to find the procedure in the service manual if I remember correctly. I don't have access to the manual at the moment, and the Konica website is still down, so I can't help you out there.
    • Synthohol
      Certified Konica Expert
      • 5735
        a clear case of the " lines of shame " go back through the installation procedures... FOLLOW IT STEP BY STEP not missing the procedure listed.
        Please in future posts post in your native language and in English.. not everyone one here knows Spanish and aren't going to use a translator to view your posts.
        Normally I'd throw the RED CARD but I have been chewed out for such actions .
        also being a newbie I'd suggest you review the FORUM RULES here ---> https://www.copytechnet.com/forums/misc.php?do=vsarules
        • romario
          • Jun 2020
          • 185
          ]Excuse me It will be that you can help me with the steps
          thanks
            the steps are ln the installation guide and the service manual.
            • copier tech
              • 8101
              These lines occur you you have not set the machine up from new.
              Since this is an old machine it can't be new, have you done work on it?
              Bizhub C454 C554 Installation.pdf
              • fatduke
                • Jun 2020
                • 75
                Dear pal
                "LINES OF SHAME",
                install and setup machine again.
                Don't forget to set the correct date/time while installing.
                Cheers
                • romario
                  • Jun 2020
                  • 185
                  [ADJUNTO] 46352 [/ ADJUNTO] [/ CITA]
                  thanks for your help friend, I did not have the installation steps, very friendly
                  [COLOR=rgba(0, 0, 0, 0.54)]
                  [/COLOR][COLOR=rgba(0, 0, 0, 0.54)]
                  [/COLOR]
                  thanks
                  • copier tech
                    • 8101
                    [/COLOR]
                    No problem. Hope you can understand it Ok in English.
                    • romario
                      • Jun 2020
                      • 185
                      no problem. Hope you can understand it ok in english.
                      a question what country are you from
                      thanks
                      • copier tech
                        • 8101
                        • romario
                          • Jun 2020
                          • 185
                          [ATTACH=CONFIG]46360[/ATTACH]
                          you can get a konica minolta c1060 pro fiery and do business
                          thanks
                          • drowranger
                            • Jul 2015
                            • 122
                            This happens due to device not runup properly. Press Stop>1>1>4>4>Clear on service mode and change the time/time zone and make sure to press apply at the bottom of the screen to fix this issue.
                            • romario
                              • Jun 2020
                              • 185
                              THANKS FRIEND, WE ALREADY SOLVE
                              [/COLOR]
                              thanks
