8 series K vs CMY drums. What's the diff?
  • Don N.
    • Nov 2011
    • 409
    Question I posed on another thread about drum noise... This is not about that.
    I'd really like to know why the claim that the k drum is not the same as the cmy for the 8 series as it has been for the 0 and 4/e series. Yes there's a plastic stopper (easily removed). Then there's the chip. What else? I'm told you can't just chip an 8 series k drum as cmy... Why?
    • 23010
    Re: 8 series K vs CMY drums. What's the diff?
    So you'll pay a lot more for the color drums? =^..^=
    • Don N.
      • Nov 2011
      • 409
      I would think that a K drum plus cmy chip = color drum. Same on c220 DR311 and c224e DR512 but, I have it from a "respected engineer" at a vendor that insists he has a tested & proven solution but without that, you can't get away with it on an 8 series dr313. I don't want to just jump and say B.S. If he's being truthful, he's sitting on a lot of money to be made. Exactly the motivation for lying as well. We put a K & CMY side by side and see nothing evident but the side stopper & the chip.
      Anybody???
      • femaster
        • May 2011
        • 1523
        Since I answered this in the other thread, here is a link to the answer. It will explain perfectly what the differences are...
        Bizhub C258 high pitch whine when copying/printing
        • Don N.
          • Nov 2011
          • 409
          Saw that. Thanks again!
          • fatduke
            • Jun 2020
            • 75
            Hi pal,
            for my own personal exp, you can't do the trick of CMYK on K drum like past series (chips included)
            I had trouble and then on this 8 series you need to buy original 8 series colour drum because either screws in new drum are calculated, so if you don't want to replace all plastic case of past series with plastic case of new 8 series for refurbishing all drum, for me, don't waste time and buy original series 8 color drum.
            I hope I was clear in explanation.
            Cheers :-)
            • femaster
              • May 2011
              • 1523
              I have made a correction and clarification post with regards to my previous post on the subject at the link below...
              • copier tech
                • 8210
                Yes you can fit K to YMC. Swap the black plastic clamp behind the front blue cover & swap over the spacers from the ends of the drum & of course the chip.
                • tsbservice
                  Field tech
                  • 8061
                  Watch out for restyled DR313K drum unit where you cannot just swap end caps from color to K drum as before.
                  • copier tech
                    • 8210
                    Why, what specifically have they changed?
                    • tsbservice
                      Field tech
                      • 8061
                      The endings are redesigned. You byu new fresh K OEM drum from KM and will see. Can't just swap end cap with spacer.
                      • copier tech
                        • 8210
                        What endings? You can simply use these from the original image unit!?
                        • tsbservice
                          Field tech
                          • 8061
                          Are you from Geheime Staatspolizei? What you didn't understand?
                          • copier tech
                            • 8210
                            • REGSIS
                              • May 2016
                              • 436
                              I didn't have an oportunity to try this yet but can it be done by removing parts from DR313K and fitting them into DR313CMY used unit?
                              It take some time but saves a lot of money if machine is yours out in lease.
                              Parts for exchange: Drum cylinder, cleaning blade, charging roller, chargin roller cleaner.
                              I never played with these on customer owned machines.
                              Always sold them new CMY drums whatever series.
