Bizhub C654e vertical color lines
  • fntsy
    • Aug 2008
    • 26
    #16
    Re: Bizhub C654e vertical color lines
    Originally posted by Synthohol
    Just a thought, don't use the thick paper setting. Use special\user paper setting with the GM2 rating
    See if that makes a difference. Hell, try envelope setting.
    Also check the neutral to ground at the outlet, anything over 1/2 a volt is unacceptable and may be a ground issue.
    OMG, thank you. Envelope setting works. No lines and the toner is well fused on a 250 gsm paper. A good work-around.
    Still - what a puzzling problem. Maybe firmware issue?
      • 23009
      #17
      Perhaps the thick paper setting for A3 is changing the print speed? Good call on the Envelope Media Type.
      Maybe try a different level of firmware? =^..^=
      • Synthohol
        Certified Konica Expert
        • 5847
        #18
        im on the fence about firmware vs HV in this case.
        it appears that when idle the DV has put this line on all the drums and the belt picked them up so the image was made on top of the residue lines.
        if you want to try firmware i can help.
        if you want to try an HV, that i can only help with a part#
        glad the workaround helped, not the first time ive had to change media type because the standard settings do something screwey.
        im curious though if its all OEM toner and parts or aftermarket. not judging since we all dig our own graves one way or another
          • 23009
          #19
          ... glad the workaround helped, not the first time I've had to change media type because the standard settings do something screwy...
          We recently had a C754e that fuser multiple imaged only on one specific media (199gsm on the package, 210gsm on my scale), only when set to Plain, Thick2, and Thick3 media types. Technically it's Thick2.
          Thick1 works perfectly. I don't have a good explanation. =^..^=
            NO it's a paper weight/type setting problem
            • fntsy
              • Aug 2008
              • 26
              #21
              The same setting with the same paper works on another machine.
