Do those aftermarket wifi adapters work with a copier? I guess you plug adapter into an electrical outlet and ethernet cable from copier to adapter and than copier can be setup through wifi. Customer wants to put copier on lower level and router is on 2nd level. Too far for hard wired. Good wifi signal where copier will be located. Do these adapters work for this application?
I've never had much luck with the Kon/Min installed optional wifi and blue tooth accessories. Hard to connect and never worked right.
Thanks in advance
Thanks in advance
