Bizhub
  • bmwmick
    • Jul 2019
    • 27
    Bizhub
    Re: Bizhub
    Mick,
    Thanks for the explanation... I have just one question as of now...
    MIND CLUING US INTO -=WHAT MODEL BIZHUB ARE YOU TALKING ABOUT? =-
    • bmwmick
      • Jul 2019
      • 27
      • bmwmick
        • Jul 2019
        • 27
        Re: Bizhub
          Re: Bizhub
          Looks like you need to reset the unit.. should not show generic. Maybe someone else can help you.. I'm out.
          • Woxner
            • Jul 2011
            • 849
            Re: Bizhub
            what is the model on the door? you need to change the soft sw to read machine. set sw 10 to hex 02 this will give model on config page. you can do a network reset is service mode to see if tab shows up
            • femaster
              • May 2011
              • 1508
              Re: Bizhub
              On config page it’s says Generic 20C-4
              Yeah, that thing is messed up, should never read generic. Something got pretty scrambled in that thing. Probably would have been easier to just look at the label on the front of the machine. Based on the firmware, it looks like it should be a Bizhub C203/C253/C353 series.
              • copyman
                Owner / Technician
                • Sep 2005
                • 4712
                Re: Bizhub
                Yeah I remember the NEC cross to the C203 series would have the generic firmware and you would get the moons on the display when booting up. Had a few kon/min with the generic firmware and moons and they worked fine.
                • tsbservice
                  Field tech
                  • 8019
                  Re: Bizhub
                  +1
                  • bmwmick
                    • Jul 2019
                    • 27
                    • zoool
                      • Nov 2016
                      • 52
                      Re: Bizhub
                      to make NIC you need nvram recovery to this specific machine.
                      write it on CF card and pull to machine.
                      then turn on and preform NIC
                      • blazebusiness
                        SanDiegoCopierRepair.com
                        • 1257
                        Re: Bizhub
                        Hi guys
                        Thanks for reply’s so far
                        There is no model on front door
                        Just a label with the name
                        Develop
                        So I will remove this and see
                        What it is
                        As it’s been rebadged
                        How do you reset the Nic ?
                        Look at the rear of the machine or maybe even the left side of the copier - for a label giving you the make/model , serial number and the year manufactured.
                        • KMFLT3CH
                          • May 2017
                          • 240
                          Re: Bizhub
                          Generic 20C-4 is a bizhub C203
                          As someone else said, you need to change a dip switch to reflect the correct model:
                          1. Access the Service Mode.
                          2. Select System 2.
                          3. Select Software Switch Setting.
                          4. Enter Switch No. "10"
                          5. Change Hex Assignment to display "02"
                          6. Click on Fix.
                          7. Click on End.
                          8. Power the MFP OFF/ON.
                          9. Print another Configuration Page. Page Header should now be changed to Konica Minolta.
                          To reset the NIC, go back into Service Mode > System 1 > Initialization > Network Setting Data > Start button > OK > Reboot.
                          • tsbservice
                            Field tech
                            • 8019
                            Re: Bizhub
                            2. Select System 2.
                            6. Click on Fix.
                            7. Click on End.
                            Not sure abot switch 10. In case it's Develop or Olivetti or other rebadges it should NOT be 02.
                            It must be 02 for KM machines.
                            And have to correct myself. If machine is C203 or its analog NIC reset is performed by NVRAM procedure not in Sys 1 menu. Zoool is completely right.
                            • femaster
                              • May 2011
                              • 1508
                              Re: Bizhub
                              Yeah, in a later comment he stated it said Develop on the front door. I don't know what the hex number should be for this brand. About all I can suggest is to keep trying different numbers until you get one that comes up as Develop. Hex 01, 03, 04, 05. If I remember correctly, they are all low numbers in a row, so it shouldn't take but a couple attempts to find the correct one.
                              Just getting this set correctly might fix the networking issue. I know that when I was messing with a machine one time, changing this value, I noticed that network settings were wiped out each time I changed the value of switch 10. Just a guess, but that might be all that is wrong with it.
