KM C284 blurry prints
Re: KM C284 blurry prints
Hi there, been a while since I worked on KM kit but was asked today to look at. C284e which was blurry, it looks as if the colour registration was out. I couldn’t find the adjustment for it in the service mode, there were some manual adjustments but not a auto colour registration adjust I was expecting to see? I’ve got t9 go back with a cyan drum and will need to adjust the colour registration when I get back, so any heads up on what to do would be useful.
cheers guys.
When you go back with the drum clean the patch sensors & run gradation adjust either from CE mode or in admin settings.
Gradation AdjustmentLet us eat, drink, and be merry, because tomorrow we may die!
You can also reset the expired items with new chips, but you may not get the necessary quality, given the situation of the expired items.Comment
Can I disagree with that?
I use chips expecially for drum unit (only some series) after gradation test (C-M-Y-K), if status seems good I use them again for a few months so I save a lot of money really.
If not, i replace with new original one.
CheersComment
So lets say you have a set of image units that have gone over life but the print quality is still perfect, why replace anything?
When you fit chips to an old image unit you are basically 'tricking' the machine into thinking it has a new unit, the machine will then run a gradation adjust on an old drum!
So please tell me what are you gaining from this other than the consumable counter being reset?
Please make sure IDC sensors and laser glasses, charge grids are clean before performing gradation . I would check the condition of the drums before resetting as well.
Like copier tech said the last thing you need is dev to arc out through a worn drum.Comment
Ok here is my argument against these chips.
Resetting items may actually cause the old units to fail sooner than they would have, or potentially result in worse quality output, because the machine is will now be adjusted to demand a higher standard of quality from the old parts as it will now think they are new.A Ricoh Service Tech for 7 year. A Konica Minolta Service Tech for 7 years. Now, KM service manager for 4 years.
My Ricoh knowledge is slowly dwindling away at this point. Many things have been lost to time...Comment
When I said about resetting the units, I made it clear that there could be problems with having expired items.
I should actually have told you to reset the items.
In our rented printers we do this procedure all the time. Knowing the situation of the items, if there is a need, we do the reset without replacing the items. If there is a need, we also do it.
I may have expressed it wrong because of my English. I'm sorry.Comment
I will try to explain myself.
I understand English is not your first language however there is no benefit from resetting ANY part without replacing it.
The ONLY counter I reset with out replacing is the ozone/toner filter.
1. To wrongly deceive the customer giving a false impression that the machines parts are new
2. To use the color chips to install a brand new oem black drum unit in one of the color positions saving the customer $$$$$$$$.sigpicAnything can be made to work if you fiddle with it long enough- San Diego Copier Repair.comComment
Regards Mark
https://copierservices.simdif.comComment
