Konica Minolta bizhub C360 - Paper Jam 11-01
  • femaster
    • May 2011
    • 1519
    #16
    Re: Konica Minolta bizhub C360 - Paper Jam 11-01
    Originally posted by allan
    Yes that will be affordable to do but the shaft only in my experience. Don't get it often that a clutch will fail before 250K. Found that my method works ok.
    Those one way clutches last forever.
    I agree. In my 8-years working with KM, I have only ever replaced a set of oneway bearings once, and that was when I first started out. The machine probably didn't need them, but I was inexperienced with KM machines at the time and didn't know any better. Cleaning them at every tire replacement, yes, but have never had the need to replace.
    Taking some Scotchbright and lightly scuffing the area where the bearing rides works perfectly. We have many machines out in the field with well over 3-million pages through them, and have never needed to change a oneway on any of them. Scuffing the shaft(s) has had no ill effect on the oneways ability to grab and work properly on those or any of our other machines. The shaft only needs a light scuffing, just enough to remove the mirror finish and dull the area where the bearing rides. If any metal is removed at all by doing this, it is so minimal that it makes no difference at all.
    • HOSTAKI
      • May 2019
      • 23
      #17
      Originally posted by mike_hartung
      Talking about the one way feed bearings right next to the pickup roller and the feed roller. They are called feed clutches in the konica minolta parts book. They fail quite often. Replacing these one-way feed bearing clutches and cleaning the shaft should solve your problem.
      I have uploaded a video of the actual two paper pick ups I am talking about
      Please see this and comment !
      You see something sliping ? I don't.
      • tsbservice
        Field tech
        • 8042
        #18
        You cannot test easy sleeping OWs. Better swap them with second(working) paper feed drawer ones to see.
        • HOSTAKI
          • May 2019
          • 23
          #19
          Both of the Trays (1&2) have the same issue .
          Could it be that the main motor is giving that pick up problem ?
          Anyone have the Bizhub C280 specific parts diagram on a link somewhere ?
          • tsbservice
            Field tech
            • 8042
            #20
            Parts Catalog > Konica-Minolta > bizhub C280 > page 16
            • ferro10
              • Jun 2015
              • 117
              #21
              pick up rollers are to be changed.
              Clean the metal shaft surely the unidirectional clutches slip.
              • HOSTAKI
                • May 2019
                • 23
                #22
                That would be the number 11 on the parts diagram
                • ferro10
                  • Jun 2015
                  • 117
                  #23
                  yes
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4750
                    #24
                    Originally posted by Synthohol
                    The following is my personal POV and experience and in no way is intended to cause controversy with conflicting views from other members
                    Scuffing the shafts where the bearing ride is done the same direction as the shift from end to end.
                    Use a 3m scotch Brite or emery cloth just enough to get rid of the mirror finish.
                    I have never in 23 years heard of using oil on them as the last thing I want is lubrication where I need good grip by the needle bearings.
                    I don't understand why a lubricant is needed for grip. I scuff the shafts, soak the one-ways in IPA and clean with a rag and a blast with a can of air to dry.
                    Unless the shaft is worn enough that there is a noticeable 'divots where the bearings ride the method I use has worked literally thousands of times.
                    Scuffing the burnished shaft in the same direction the rollers turn also does not make sense to me as that will cause the needles to only ride the high spots of the surface instead of better lateral contact.
                    All you can do is listen to all the advices offered and make up your mind which way to go.
                    Trial and error will help you form a routine to handle procedures like this.
                    Short 'for instance'...
                    I recently watched another tech starting to remove a fuser to replace a t-belt on a 4 series. I laughed out loud. He said it's the only way the belt will come out. I then showed him the 1 stupid screw on the upper guide plate on the t-belt. Removed guide and now the belt comes in and out without obstruction or extra work removing the fuser.
                    Now it's the only way he does it.
                    But he had to perform it both ways and made his decision to try it the less laborious way and it all worked out
                    Good luck and happy trials
                    This has been discussed several times on this forum and I agree with you 100% and have done the same thing for many years with scuffing the shaft from end to end direction, cleaning one ways with alcohol & blowing out with canned air. Think I recently posted this was told to me at Kon/Min school many years ago. I posted it after some discussion about scuffing "around" the shaft. Also NO lube!
                    If you are still getting "misfeeds" with new PF rollers, take out the PF unit and clean one ways & scuff shafts properly, it works!
                    • Oystercopy
                      • Oct 2009
                      • 623
                      #25
                      Just my 2 cents, but..
                      Almost never have had to replace worn shafts, except back in the 80s on Panasonic feeders.
                      On the newer machines, like KM, the shafts are a stronger steel, and don't wear down to the point they require replacement.
                      However, using scotch brite (or other abrasive) to wear down the shiny part of the shaft is the only thing I would ever consider doing any more. In fact, the KM machines are built so well that
                      I almost NEVER have an issue with one way bearings on these boxes whatsoever.
                      But if you're going to take the time to service them, just getting the gloss worn down on the shafts is all you really need to do. And I don't put lube on them, to be sure. I believe this would complicate the
                      needle bearing's ability to grip and release the shaft the way they should. But referencing the old Panasonics again, on those boxes you could physically SEE the area under the bearing actually WORN DOWN to
                      the point where shaft replacement was required. Now, on those bearings, we did pack them with grease, because the theory was that the wear factor on the shafts would be too great, so we needed something to
                      "push" the needles more towards the shaft, so that they would have better gripping capability, and that seemed to work, especially if you didn't have new shafts and bearings in your car stock at the time.
                      Hope this helps someone!
                      OC
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4750
                        #26
                        OC
                        Agree about the newer Kon/Min one ways not needing as much attention like some models in the past. Can't tell you how many times I've cleaned the one ways on the BizHub C203 series, definitely 100's of times back in the day when these were in service! Seems like every call I was cleaning the one ways, or for a long time was replacing the one ways. And it sucked on that model to get the PF units out, i.e. taking off manual feed tray etc etc. Much easier on the newer models.
                        Then a friend from Kon/Min told me he has "never" replaced the one ways so from that day on I've only replaced a few, cleaning & scuffing has always worked.
