Bizhub 4 series HDD Size
  • copier tech
    • 8165
    [Misc] Bizhub 4 series HDD Size
    Hi all,
    Quick question, most Bizhubs come with the 320GB HDD & from what I have seen this is more than enough.
    Now as we know they do fail & we fit another drive the same size, fine.
    However, I have a box of old 80GB drives could I use these?
    Mainly for low volume light use machines, 5 scans per day etc.
    Has anyone tried?
  • jwai
    • May 2018
    • 508
    Re: Bizhub 4 series HDD Size
    320GB or above.
    • escalante
      • Sep 2018
      • 115
      In series 3 they are Sata hard drive. It had or has 250 GB and 320 GB.
      On the Bizhub 360 420 500 they were 80 GB, but they were IDE hard drives
      Enviado desde mi SM-J701M mediante Tapatalk
      • Synthohol
        Certified Konica Expert
        • 5842
        agreed, i tried a 250Gb in a c454 and it didnt play nice at all.
        maybe it would work on monochrome but any color konica should be 320 or larger.
        • REGSIS
          • May 2016
          • 435
          Official size is 250 GB for 4 and 8 series, and even for i series the same size but SSD.
          You can put 320GB or 500GB drive inside but it will be formated and using 250 GB space.
          What was problem with yours?
          Format physical, logical, movie data and you are good to go!
          • copier tech
            • 8165
            Thanks for the replies the 80GB drives are SATA.
            I will put them in a USB caddy & use as back up etc. Shame to bin them.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4712
              [QUOTE=REGSIS;1563552]Official size is 250 GB for 4 and 8 series,
              I've have only seen 320GB in 4 series. Never 250GB
              • REGSIS
                • May 2016
                • 435
                I've seen 250 and 320, depend what was available at the time of manufacturing. I've even put 500GB drive when replacing defrctive one, but after format all of them shown 250 GB because it is the amount of space used by machine. Any space above 250GB is useless and is not used. Check it out.
                • copyman
                  Owner / Technician
                  • Sep 2005
                  • 4712
                  Good to know. I just looked at C224e series specs and surprised to see "standard" HDD is 250GB. Since every HDD I've replaced on the "4" series was 320GB assumed I needed to use that size.
                  Learn something new every day.
