i series reset tools
  • jwai
    • May 2018
    • 507
    Hi everybody
    I wanna ask KM provide reset tools for i series?
    Best regards,
  • tsbservice
    Field tech
    • 7981
    Re: i series reset tools
    Are you solving specific problem or just in case?
    • jwai
      • May 2018
      • 507
      HI tsbservice,
      One C250i has issue that boot up only 25%, later on I will take CPUB and SSDB for testing.
      I consider when CPUB is not relative with this case, I can initialize it with this tools like the procedure on previous 4e series.
      • Bix
        • Apr 2018
        • 1421
        Change the STRB and update the firmware to G00- B6
        • jwai
          • May 2018
          • 507
          Thank you Bix.
          Since I tried the following :
          - Enter the tech Rep mode by reset key + main SW on
          - Enter the load FW mode by stop key + main SW ON
          They all display 25% boot up screen with black dot only, so I'm not sure the condition of CPUB is ok or not.
            • 8132
            Originally posted by jwai
            Thank you Bix.
            With the iseries you use the small button behind the control panel to load firmware.
            • Woxner
              • Jul 2011
              • 840
              one way to test storage board is to remove it and see if it will load firmware. it wont load controller though
              • Woxner
                • Jul 2011
                • 840
                and the 8 series reset tool is used for i series as well
                • jwai
                  • May 2018
                  • 507
                  Yup, I really use this way attempt to load the B6 firmware.
                  However, it stay on 25% boot up screen with up left corner dot only.
                  • jwai
                    • May 2018
                    • 507
                    I don't have this tool
                    • jwai
                      • May 2018
                      • 507
                      Thank you your advise, I tried this day however it stay same. ( 25% boot up screen with black dot )
