biz c250 error 2558
  • Gab
    • Aug 2015
    • 671
    biz c250 error 2558
    This error appeared . Executed reset with no result. Toner and drum OEM also drum has made about 18k .
    any idea?
    Re: biz c250 error 2558
    any idea?
    yeh get the damn manual
    you seem not to read the manual very important in this business.
    • femaster
      • May 2011
      • 1514
      any idea?
      As Phil said, get yourself a manual. You can't expect to work on things if you don't have the proper reference materials. Until such time, here is what your code means: Error Codes > Konica-Minolta > bizhub C250 > Code C2558
      • copyman
        Owner / Technician
        • Sep 2005
        • 4724
        any idea?
        Take black toner out and shake really well and put back in. Keep opening and closing front door until it resets. If not after a few minutes you should be able to go into service mode even with the code. See what the black toner % reading is?
          it seems he doesn't EVER have a manual for anything.
          • rrrohan
            • Sep 2011
            • 1977
            if its a C250 and not a C250i the toner is so old and could just need a good shake.
            Is the hopper empty?
            • Gab
              • Aug 2015
              • 671
              Of course i have service manual but frequently in the field we are faceing problems that to fix not refered in manuals but in experience. that's i an asking
