Konica Minolta c308 - stuck in self diagnostic mode
  • Kenny
    • Jun 2009
    • 530
  • Max
    • Oct 2011
    • 561
    Re: Konica Minolta c308 - stuck in self diagnostic mode
    Screenshot of diagnostic screen ? Reset error code list and check again after a few days/after diagnostic. I would start there 1st.
    • tsbservice
      Field tech
      • 8028
      At what version is current machine FW?
        • 23009
        You can get this exact symptom if you update the firmware, but do not change the DIPSW in the bulletin. =^..^=
        • Terna247
          • Jan 2019
          • 64
          I had a call where a machine was preparing the "user box" and "fax/scan" to infinity... No job was coming in.
          It was solved with logical formatting of the SSD and a halfway physical format of the HDD.
          Sent from my Infinix X606C using Tapatalk
          • femaster
            • May 2011
            • 1514
            Halfway physical format of the HDD?
            I'm thinking this is some translation issue, but if not, could you elaborate on that...
            • Terna247
              • Jan 2019
              • 64
              Femestar... While running the the physical format I stopped on the way...2% I guess. Switch off from the main switch. It gave an error code CD001 I think. Service mode sytem1 iniatialization>>clear all data>> off.
              powered after 10 secs and all the jobs sent spooled up.
              • byronf
                Senior Member
                • Sep 2017
                • 109
                Hi Kenny,
                You can stop the MFP to automaticly perform self diagnostics by adjusting dip sw 163 to hex 00.
                Lets us know
