Change speed. C224e to C364e
  • kmuserpl
    • Mar 2020
    • 2
    Hi.
    How I can change speed in C224e to 36PPM?
    Thank all for answers.
  • copier tech
    • 8164
    Re: Change speed. C224e to C364e
    Originally posted by kmuserpl
    Hi.
    Fit a complete set of boards from a C364e inc the SSD & HDD.
    โ€‹
    • greglogston
      • Jul 2018
      • 34
      Hi.
      This a serious question????
        • 16395
        Have to tried putting a turbo charger on it? Maybe some headers and 4 barrel carburetor? Oh wait....
        • Synthohol
          Certified Konica Expert
          • 5835
          the same way i can upgrade my 27" monitor to a 40" monitor.
          i buy a 40" monitor.
          [/snarky]
          or run 6"x6" paper. that will do it too.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4709
            I think Kon/Min would make that really hard to do.
            Heck the last time I did that was a mono Biz 200 to a Biz 350. Back than it was only only a wire change & re-programmed chip. My friend cracked the program and re-programmed the chips for the dealership he worked for. Saved the owners a lot of money. But as usual to show their appreciation they gave him a pat on the back and said good job! Not even thank you!
              • 37513
              In the early days of bond paper copiers other than Xerox, we could increase the speed of the Royal RBC I from 10 ppm to 12 ppm by changing the main motor. The machine only had a single 125 sheet paper tray so a lot of people came up with add on options. There was a rolled paper feed that attached to the left end. GradCo made a couple of sorters that could be adapted to a number of makes and models. The company I work for made a lower tray that held 2 reams of paper and a coin operation box.
              • tulintron
                • Jul 2014
                • 668
                As our friend Copyman said, only a few threads and a small change in the programming changing the interval between pages to a smaller one. Just programming and some wires.
                But I do not advise doing this to make money. This is called FRAUD.
                https://www.copytechnet.com/images/smilies/cool.pngNada como dia apรณs diahttps://www.copytechnet.com/images/smilies/cool.png
                  • 37513
                  If KM is anything like Ricoh you will also need a valid serial number for a C364e. After that anyone, like a competitor, who compares the serial number on oh lets say the counter printout with the serial number plate will expose your fraud.
                  • Copier repairman
                    • Aug 2019
                    • 86
                    Available.
                    But it is unfortunate.
                    I can't tell you.
                    Because my status indicator is red.
                    • Jumping Jack Flash
                      • Jul 2009
                      • 66
                      I think "kmuserpl" and "Copier repairman" are the same guys
                        • 37513
                        I doubt it. One is in Poland. The other is in South Korea.
                          Originally posted by Copier repairman
                          Available.
                          I can't tell you.
                          rep points don't have a damn thing to do with it..
                          you have been touting scam devices... maybe not illegal in your neck of the woods but very ILLEGAL in most the rest of the world.
                          • tulintron
                            • Jul 2014
                            • 668
                            what guarantees you that the profile information is true?
                            • Walterj
                              KONICA MINOLTA
                              • Jun 2017
                              • 89
                              Hi.
                              Because they ask stupid, if you want to know.
                              Research and analyze how the team works first.
