Bizhub c364e gradually blur out
  • KM7155
    • Aug 2008
    • 146
    Hi Guys,
    any solution for c364e after printed 6/7 pages, it will become blur for the rest of the print job?
    sample as attached. already change dr512k, dv512k, transfer belt unit, problem still the same.
    thanks in advance.
  • femaster
    • May 2011
    • 1508
    Re: Bizhub c364e gradually blur out
    You'll need different pictures, the attached ones are so small can't make out anything in them.
    • Synthohol
      Certified Konica Expert
      • 5840
      can you try running multiple halftone test pats in service mode?
      then post a full size crappy one, its easier to identify componant issues.
      thanks.
      • KM7155
        • Aug 2008
        • 146
        sorry, is P&C, thats why cant snap the whole page. will supply the picture again
        • KM7155
          • Aug 2008
          • 146
          thanks.
          sure will do, will post the image again, thanks
          • Synthohol
            • 5840
            have you cleaned off the laser glass with the wand?
              • 23008
              I'm thinking about the developer agitation clutch. =^..^=
              • tsbservice
                Field tech
                • 8019
                Agree with BC check K developer unit drive solenoid. It's behind PWB box and few pieces of electrical tape may be enough to keep it working until replaced(or forever).
                • KM7155
                  • Aug 2008
                  • 146
                  yes, done that.
                  this problem happen after i have change the dr512k,dv512k and take out the ITB to service.
                  before service, everything is just fine.
                  • KM7155
                    • Aug 2008
                    • 146
                    Hi, u mean the drive clutch? what is PWB box? is it the waste toner box? refer to the picture, is it the clutch u mentioned.
                    thanks for the idea.
                    • tsbservice
                      Field tech
                      • 8019
                      It isn't clutch it's solenoid. SD4 on that picture.
                        • 23008
                        Thanks for the correction, tsb. It is the developing solenoid SD4 as seen in your illustration. And the PWB box that they are referring to is the metal cage containing the circuit boards on the rear of the machine. If you not very confident you should get a professional to do it. =^..^=
                        • KM7155
                          • Aug 2008
                          • 146
                          thanks guys for the advise, @BC, i can do it.
                          will post the outcome once i have done it.
