KM C227 Vertical Lines when the print has coloured elements on the page
  • Mister C
    • Nov 2020
    • 6
    [Misc] KM C227 Vertical Lines when the print has coloured elements on the page
    Hi there!
    End user is struggling with a KM C227 from some time now. The machine was constantly printing with a magenta hue on all colour pages and the calibration procedures helped a bit whenever the issue was present.
    All drums and developing units were changed in the past as they were approaching end of life, but the magenta issue came back after a while and it consumed extra toner. There was also a lot of ejected toner inside the machine.
    Now, the machine prints thick vertical lines which seem to be composed of Y, C BK and some M. I've attached a sample print.
    Any idea what could be causing the issue? Drums and belt look ok. Possibly the laser unit is dirty?
    Moreover, the machine also shows and error C-0202 for Tray 1 . I found some jammed paper in the lift mechanism for Tray 1, but it seems that the motor or sensor is damaged.
    Troublesome machine, this one
  • Synthohol
    Certified Konica Expert
    • Mar 2016
    • 5824
    Re: KM C227 Vertical Lines when the print has coloured elements on the page
    if i was to take an educated guess, id focus on the transfer belt and its gears.
    to me without hearing it operate, it looks like the cleaning assy gear on the belt is skipping and causing a bounce to the cleaning blade.
      • 23007
      The C0202 is most often caused by paper being overloaded. Once you get the paper from behind the tray perform a System Error Clear to reset the error. =^..^=
      • tsbservice
        Field tech
        • 8013
        Check erase LEDs.
        • Genotrom
          • Feb 2020
          • 77
          Check erase LEDs.
          what's this called in the manual? I am curious to see how to disassemble
          • tsbservice
            Field tech
            • 8013
            Here's the video from one of the greatest KM techs around:
            Bizhub C227 kept destroying yellow IU's - Here's why (Technicians ONLY) - YouTube
            Btw, this is from basic copy process 101.
            • edwards63
              In my opinion, there is a defective primary charge roller PCR of the black drum unit. look at the top of the printed sheet at the first two strips and you will see white dots that are repeated plus oblique lines similar to the structure of the cleaning roller of the PCR. Try to replace PCR to another from any used drum or image units or replace black drum unit assembly.
              • byronf
                Senior Member
                • Sep 2017
                • 109
                I would suggest you upload the half tones (KYMC) at 255 and 120 to begin the trouble shooting.
                • Mister C
                  • Nov 2020
                  • 6
                  Thank you for this. It solved the issue with C0202.
                  • Mister C
                    • Nov 2020
                    • 6
                    Check erase LEDs.
                    Good tip, this one. I will remember to check in future devices, but in this case all 4 LED's are functional.
                    • Mister C
                      • Nov 2020
                      • 6
                      You might be right. After a second checkup, I've noticed that lines of toner are somewhat hardened on the transfer belt. As if it wasn't cleaned properly.
                      Anyhow, I also observed that the belt was punctured in 2 places so I recommended the end user a new one.
                      I'll reply with how the device operates after I change it.
                      • copytech,mike
                        CopyTech,MIKE
                        • Jun 2014
                        • 261
                        Originally posted by Mister C
                        Hi there!
                        I havea C227 today doing the same thing. It almost looks like its printing a test page. 4 bars of all colors. Im guessing a bad transfer belt unit. I dont think its a bad laser unit or any so called memory card.
                        • copytech,mike
                          CopyTech,MIKE
                          • Jun 2014
                          • 261
                          No its not a charge roller. It prints all 4 color1/2 inch wide bars in color mode only. Almost like a test pattern but with the main copy image in the background. Possible bad transfer belt is my guess.
                          • copytech,mike
                            CopyTech,MIKE
                            • Jun 2014
                            • 261
                            Erase LED is not a bad idea on this.
                            • copytech,mike
                              CopyTech,MIKE
                              • Jun 2014
                              • 261
                              I dont think so because it makes a perfect blk and white copy in black only mode.
