[Need Help] empty lines on printed document
  • Omar Faris
    • Oct 2017
    • 15
    Hello,
    i need some help about my Konica Minolta Bizhub 350
    The problem is that all the printed documents has a two or more empty lines,
    i have added with this post a picture of the problem,
    any reply will be appreciated.
    • 23010
    Re: [Need Help] empty lines on printed document
    If that page was SEF (short edge feed), I'm going to guess that you've got an obstruction under the doctor blade, leaving a blank band on the developing roller. =^..^=
    • Max
      • Oct 2011
      • 563
      Dirty laser glass? Try the magic wand.
      • copiray
        • Feb 2019
        • 29
        Is the strip completely blank? Does it always appear in the same place?
        If so, it is possible that something is clogging the developer roller or that the laser glass is dirty
        • tsbservice
          Field tech
          • 8041
          Both mentioned already. Pls try harder.
          • femaster
            • May 2011
            • 1519
            The picture you shared is REALLY small, so it's hard to make a proper determination. Like others have suggested, I'm leaning towards junk caught in the dr blade leaving those void areas. It's very common on these for dust and junk to get caught in the blade because this model recycles the "waste" toner.
            One other thing that I have seen happen on these is the foam strip attached to the erase lamps starts to breakdown because of the age. I've had at least 2 occurrences where a small piece of that foam was hanging down from the erase lamp board and blocking the laser path. It took me quite a while to find that issue, because it's not easily seen unless you think to bend over a bit more and look up.
            • Hansoon
              • Sep 2007
              • 3391
              Yes and yes!
              Hans
              • mearmi
                • Oct 2010
                • 350
                Originally posted by Omar Faris
                Hello,
                In these models, Drum and Developer both can make this problem.
                What did you replace???
                • Blizzoo
                  • Aug 2013
                  • 610
                  I had that once on a 250. I found the fault quite easy as the hanging foam strip was quite obvious standing in the way of 'the beam'
                  • Omar Faris
                    • Oct 2017
                    • 15
                    The page is A5 Format, and i think it's what you refer as SEF, you can see this picture
                    https://www.dropbox.com/s/n11qt8i4fkdy5b7/PIC%20D2.jpg?dl=0
                    • Omar Faris
                      • Oct 2017
                      • 15
                      i dont think that the laser glass is dirty because scaning to pc gives good image, and printing from pc gives the same problem, so it's not the scaning laser glass problem
                      thanks for the idea
                      • Omar Faris
                        • Oct 2017
                        • 15
                        the strip yes is completely blank, and also it always appear in the same place,
                        thanks i will check
                        • Omar Faris
                          • Oct 2017
                          • 15
                          i tried scaning to computer it gives good image
                          i tried printing from computer it gives the same problem on printed document,
                          i think it can be the drum unit that must be changed.
                          • Omar Faris
                            • Oct 2017
                            • 15
                            Thanks for you reply, the picture i shared was not small in original, it's only when i upload it to this forum, anyway here is other pictures
                            Dropbox - PIC D2.jpg - Simplify your life
                            Dropbox - PIC T.jpeg - Simplify your life
                            • Omar Faris
                              • Oct 2017
                              • 15
                              for now i did not replace any part, i guess it's drum problem, needs to be replaced, what's do you think
